  • skids
  • Member For: 12y 6m 1d
  • Gender: Not Telling
Someone might shoot me for this but I am loyal to no oil brand, I am all about whether the product meets the required specifications.
Definitely run fully synthetic oil because the turbocharger heats the oil up and synthetic oil copes with this better.
If you want a really good oil, get penrite fully synthetic which is labelled '10 tenths 100% pao ester' . I used the standard 'fully synthetic' cause it came in a 6L bottle (instead of 5L) for $10 less. Regular oil changes is what prevents me from spending more money for the 'better stuff'.
Edited by johnxr6t
https://www.fordxr6turbo.com/forum/topic/92464-oil-brands/#findComment-1612678
  • New Member
  • Member For: 12y 11m 2d
Mate you cant go past Castrol.
CASTROL EDGE 0W-40 A3/B4
Castrol EDGE 0W-40 A3/B4 is a fully synthetic, SAE 0W-40, engine oil formulated for prestige and high performance engines. Castrol EDGE 0W-40 A3/B4 provides outstanding wear protection in performance engines designed to run at their optimum level on lower viscosity oils. Castrol EDGE 0W-40 A3/B4 should be used in engines where maximum efficiency and protection is demanded This product is not suitable for vehicles fitted with Diesel Particulate Filters (DPF).
https://www.fordxr6turbo.com/forum/topic/92464-oil-brands/#findComment-1613636
  • Member For: 17y 7m 5d
  • Dropping a turd
  • Member For: 17y 8m 2d
Is he talking about.
Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4  Castrol EDGE 0W-40 A3/B4
  • Like 4
https://www.fordxr6turbo.com/forum/topic/92464-oil-brands/#findComment-1613652
  • MattyP
  • Cruise Control
  • Member For: 13y 1m 25d
I ran diesel oil for a while,
full syn
all the zinc and molybdenum you can get
destroys cats but I don't care cause I smash em all the time anyway
https://www.fordxr6turbo.com/forum/topic/92464-oil-brands/#findComment-1613672
  • Sandtrap Motorsport
  • Member For: 16y 7m 4d
Also can wear off the coatings on your bearings & valve stems ... But it cleans up engine sludge well for a while :)
https://www.fordxr6turbo.com/forum/topic/92464-oil-brands/#findComment-1613676
  • MattyP
  • Cruise Control
That's why I only ran it through once.
Clean everything and then I've been using nulon 5w 40, 5w30, 10w 40 and ten tenths racing 10w40
https://www.fordxr6turbo.com/forum/topic/92464-oil-brands/#findComment-1613677
