Johnmal Member 39 Member For: 8y 6m 1d Posted 19/09/16 12:48 AM Share Posted 19/09/16 12:48 AM I was wondering why isn't my steering column moving all the way to the top, it still has about 5mm-10mm before its fully flush with the dash. The actual stewing hight and lowering if the wheel is fine. Any suggestions Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 1m 10d Gender: Not Telling Posted 19/09/16 12:53 AM Share Posted 19/09/16 12:53 AM When you pull the tab down to adjust it, are you able to pull the steering wheel towards you a little as well as up and down? I'd have to go outside to check mine if you're not sure. Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,434 Member For: 15y 1m 13d Gender: Male Location: Melbourne Posted 19/09/16 09:19 AM Share Posted 19/09/16 09:19 AM flush with the dash what do you mean? in the fgs the steering is quite low even when all the way up Link to comment Share on other sites More sharing options...
Johnmal Member 39 Member For: 8y 6m 1d Posted 19/09/16 11:43 AM Author Share Posted 19/09/16 11:43 AM When you pull the tab down to adjust it, are you able to pull the steering wheel towards you a little as well as up and down? I'd have to go outside to check mine if you're not sure.Yes the steering does pull out and in but doesn't go all the way up, the whole column I'm dyslexic and cannot turn off simple functions in tapatalk Link to comment Share on other sites More sharing options...
Johnmal Member 39 Member For: 8y 6m 1d Posted 19/09/16 11:46 AM Author Share Posted 19/09/16 11:46 AM flush with the dash what do you mean? in the fgs the steering is quite low even when all the way upMine seems to have a slight gap even when all the way up.I'm dyslexic and cannot turn off simple functions in tapatalk Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,434 Member For: 15y 1m 13d Gender: Male Location: Melbourne Posted 20/09/16 08:34 AM Share Posted 20/09/16 08:34 AM pretty sure that's normal hahah a lot of complaints with the tall buggers who drive falcons is the top of the steering wheel actually sits in their line of eye sight to the speedo because the steering wheel wont go high enough. 1 Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 14d Gender: Male Location: Probably above atmospheric pressure Posted 20/09/16 08:54 AM Share Posted 20/09/16 08:54 AM Yeah that affects me actually, can't quite see the 100's area/top of speedo if I have it at a comfy height. I'm only six foot but prefer the wheel a touch lower than the highest point. 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,211 Member For: 16y 9m 29d Gender: Male Location: Melbourne Posted 20/09/16 08:55 AM Share Posted 20/09/16 08:55 AM just lay the seat back further problem solved Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 14d Gender: Male Location: Probably above atmospheric pressure Posted 20/09/16 08:59 AM Share Posted 20/09/16 08:59 AM I maxxxed out my hekticness already :'( 2 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,211 Member For: 16y 9m 29d Gender: Male Location: Melbourne Posted 20/09/16 08:59 AM Share Posted 20/09/16 08:59 AM bugger Link to comment Share on other sites More sharing options...
