  • Member For: 18y 10m 20d
Hey guys. So timing cover is off and keep tossing up whether I should do oil pump. It's a zf auto that doesn't see limiter very often but yeah want some opinions from others on here. How much extra work is involved and would you go the extra ?
https://www.fordxr6turbo.com/forum/topic/92445-how-much-more-work-for-oil-pump/
  • Moar Powar Babeh
  • Member For: 19y 8m 28d
FG is engine out and sump off (or x member out and sump off) to get the pick up bolts unfortunately
  • Member For: 9y 2m 2d
I got some oil pump gears given to me by a mate that are from spool,
Since I need to change the fg sump to a b series ill be putting the gears in, should I just do the whole thing?
Expand
Wow what a bitch! I have heard (through Facebook) that it's possible to take off the engine mount bolts and lift the engine slightly.This can give enough room to get to the pickup.
Anyone have ate experience with this or can see it as a bad way?
  • Silver Donating Members
  • Member For: 11y 4m 8d
I scored a BA long motor for $150(!!!) on fleabay for learning purposes...first job will be strip down, remove oil pump and swap for atomic unit.
Around $300 saving for exchange option without having my ute off the road plus I get experience. Winning!
  • 2 years later...
  • Member For: 6y 6m 16d
So I'm thinking of replacing my fgx xr6t oil pump myself on my hoist with a complete atomic forged unit. So is the difficult part removing the x member under the engine? Why is it difficult? What can go wrong? Is the engine mounted on the cross member? Does the engine need holding up/ supporting with straps or a engine crane or what to take sump off? Anyone replaced the oil pump with engine still in car? Thanks guys
