ABS module compatibility
COR24T
  • New Member
  • Member For: 10y 10m 9d
Bought a turbo motor and loom from a sedan for my ute. Have noticed the old ABS module in my ute only has 3 ABS outputs whereas the sedan one has 4. Will my non turbo ute module plug in and communicate with the turbo sedan computer or do I have to use the sedan ABS module and run an additional brake line to the rear?
I'm assuming if they are compatible, will I then need to get it re-programmed to sync with the turbo sedan computer?
Any help is greatly appreciated.
  • XR50T
  • Member For: 11y 9m 27d
Utes aren't meant to have the sedan unit. You'll have to use you Utes old one and have the car coded if it doesn't play nice with the other parts.
