  • Dropping a turd
  • Member For: 17y 6m
Its not the oil.. Its the case hardness and rolling contact fatigue.. case not hard enough
Gaze at my lovely lobes
Edited by arronm
  • Member For: 18y 8m 27d
  On 12/09/2016 at 10:09 AM, BAXRTUTE said:
Ive got a B series head u can take? Not sure if u can use it though?
Ive pulled my atomic springs out though.
Expand
Does anyone know of the b series cams are the same as FG?
ive also heard the cams are the same between turbo and non turbo in the fg's.can anyone confirm?
  • Member For: 8y 11m 8d
  • Gender: Not Telling
I think I can recall that na and turbo fg cams were the same. Don't quote that but. If ba fg are the same you're on a winner there with free cams. I dare say he'll want a bottle of makers but :fishin:
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 17d
cams are different... BA is different to BF which is also different to FG :) (no idea about FG-X).
Pretty sure N/A and turbo are different, too (not as sure on that, though... )
  • Member For: 9y 9d
Expand
@JETURBO
@Ralph Wiggum
Either of u 2 smart farkers know if this will work?
Dont see how it wouldnt with all the b series head bolted to a f6 short...?
Edited by BAXRTUTE
  • Sandtrap Motorsport
  • Member For: 16y 5m 2d
Make sure you mark & this retain the cam caps in correct place/position. Otherwise line honing will need to be done, to avoid premature wear as well.
Basically just a heads up for people removing them etc, I found out after mixing & matching, but before it was ever near starting
  • Like 2
Ok so from ford, I gave them both mine and an LPG NA and they came u the same. THen started chatting to the guy and he was able to tell me these cams were introduced from BF2 10 /11 onwards. They are in the falcons, territory, xr's etc.
Part Numbers:
exhaust baf26250a - $395
intake baf26250b - $395
  • Member For: 17y 5m 3d
BF2 10/11?
BF ended in 2008?
Did you mean FG2 10/11?
  • Like 2
