Nic New Member 3 Member For: 8y 9m 19d Posted 06/09/16 09:53 AM Share Posted 06/09/16 09:53 AM Hi - wondering if anyone has had a similar problem and how you fixed it. BF XR6T no mods 250,000 Ks Leaking from rear main seal - seal changed still leaking. Used after market seal - replaced with genuine Ford seal - still leaking. Fitted sleeve - still leaking. Takes about one day of not being used for leak to start - leaks about 10ml of oil per day - no other leaks. Any advice would be greatly appreciated Link to comment https://www.fordxr6turbo.com/forum/topic/92410-rear-main-seal-oil-leak/ Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 11m 4d Posted 06/09/16 11:06 AM Share Posted 06/09/16 11:06 AM Sure it's the seal? Mine leaked around the rear bearing cap as I didn't put sealant on it. Rookie error. Also there are a few different sized seals Link to comment https://www.fordxr6turbo.com/forum/topic/92410-rear-main-seal-oil-leak/#findComment-1610589 Share on other sites More sharing options...
Nic New Member 3 Member For: 8y 9m 19d Posted 06/09/16 11:33 AM Author Share Posted 06/09/16 11:33 AM Thanks Gaz - you could be right - Im thinking the crankshaft might not be running true - worn bearings - but I thought these engines where bulletproof Link to comment https://www.fordxr6turbo.com/forum/topic/92410-rear-main-seal-oil-leak/#findComment-1610598 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 9y 1m 6d Gender: Not Telling Location: Radioactive wasteland Posted 07/09/16 02:11 AM Share Posted 07/09/16 02:11 AM Thinking too much Nic. Check out Gaz's suggestion Link to comment https://www.fordxr6turbo.com/forum/topic/92410-rear-main-seal-oil-leak/#findComment-1610659 Share on other sites More sharing options...
Nic New Member 3 Member For: 8y 9m 19d Posted 07/09/16 11:34 AM Author Share Posted 07/09/16 11:34 AM OK thanks - I will check it out Link to comment https://www.fordxr6turbo.com/forum/topic/92410-rear-main-seal-oil-leak/#findComment-1610764 Share on other sites More sharing options...
