PTR_NITRO_FG Donating Members 3,214 Member For: 11y 9m 13d Gender: Male Location: NOR Perth Posted 31/08/16 04:00 AM Share Posted 31/08/16 04:00 AM What did he sling you for install/zf fluid flush? Or is he still using that castrol stuff? Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 3m 14d Gender: Male Location: Probably above atmospheric pressure Posted 31/08/16 04:48 AM Share Posted 31/08/16 04:48 AM I'd say aim for no longer than 50,000km between ZF fluid and filter changes! 100,000 is aaaaages. Factory warranty expires at 100,000km so Ford get away with a cheaper TCO on the car. ZF themselves I think suggested 150,000km with genuine flid but I could be way wrong on that. Besides if you push more power than it's rated for you better clean it more too! Even more so with non genuine fluid - it's fairly cheap to do anyway, as long as they do the right fill procedure and your chosen heat exchanger/cooling solution keeps pressures close to factory it shouldn't play up, from what I've read. 1 Link to comment Share on other sites More sharing options...
Elusivef6 Member 51 Member For: 8y 7m 13d Location: SE Queensland Posted 31/08/16 06:55 AM Share Posted 31/08/16 06:55 AM Bf f6 07 Im at 350rwkw now and its cost me approx 9k :( Had some issues with my goals and what the tuner supplied earlier on. felt underdone nizpro stage 1 intercooler -works fine with back to back runs nizpro valve srpings - not the best walbro fuel pump injectors 4'dump and cat xcal3 +tune 2x tuning are inc in that cost as the 4'dump and cat wasn't done originally :( The major part in pushing the car to 350rkw was the exhaust work, I was at 278rkw without it Link to comment Share on other sites More sharing options...
boegey Member 123 Member For: 11y 1m 10d Posted 31/08/16 08:54 AM Author Share Posted 31/08/16 08:54 AM I'd say aim for no longer than 50,000km between ZF fluid and filter changes! 100,000 is aaaaages.Yer I definitely agree about the shorter intervals, what fluid are you guys using? The genuine stuff or I've read good things about the gulf western stuff? Link to comment Share on other sites More sharing options...
boegey Member 123 Member For: 11y 1m 10d Posted 31/08/16 08:56 AM Author Share Posted 31/08/16 08:56 AM Im at 350rwkw now and its cost me approx 9k...Yer I bet you wish you did the exhaust the first time lol. That's why I want to get everything done the first time so I can save on multiple tunes. We're your stock valves floating at that power or did you just do them for peace of mind. I was eventually going to go with either the crow cams springs or the atomic ones. And which walbro fuel pump did you use? Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 3m 14d Gender: Male Location: Probably above atmospheric pressure Posted 31/08/16 11:52 AM Share Posted 31/08/16 11:52 AM My tuner uses Castrol Transmax Z so that's what I've stuck with, would like to try the Gulf Western stuff one day. My BF XR6T has 320rwkw with Nizpro older style cooler, Manta 2x2.5" exhaust (twin cats), 42lb Bosch injectors (limiting factor) and intank fuel pump upgrade (Walbro GSS294 - tuner choice). Cost me about $5300 including XCAL3 box ($600), got the injectors for $200 with some luck, exhaust $1800 (new but mild steel). The cooler and pipes were about $1200 used delivered from the East coast. The rest is tune, fuel pump and fitment of exhaust by the shop. Looking to get some 1000CC KPM squirters installed by the time I enter Racewars in March next year and hopefully get about 350ish rwkw (see what happens as the car has 311,000km on it now). 3 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 9m 8d Gender: Male Location: Adelaide Posted 31/08/16 01:05 PM Share Posted 31/08/16 01:05 PM (edited) The last BF2 ZF we did came in at around $7500 and finished up at 350rwkw @ 15 psi Plaz 1000hp kit UBI valvesprings 4*/4*/3.5 exhaust siemens deka 60's walbro intank ZF cooler Port & Flapper 38mm TS IWG 12psi Edited 31/08/16 01:06 PM by JETURBO Link to comment Share on other sites More sharing options...
boegey Member 123 Member For: 11y 1m 10d Posted 31/08/16 08:24 PM Author Share Posted 31/08/16 08:24 PM That's a good price for everything listed was that including installation of everything? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m 12d Gender: Male Location: Perth Posted 01/09/16 12:07 AM Share Posted 01/09/16 12:07 AM On August 31, 2016 at 7:39 AM, .Stripes. said: edit the thread title, it's making my OCD hurt... 700rwkw. Should be killa 1 Link to comment Share on other sites More sharing options...
Franga Donating Members 256 Member For: 10y 4m 17d Gender: Male Location: Melbourne, VIC Posted 01/09/16 12:17 AM Share Posted 01/09/16 12:17 AM Math checks out. Link to comment Share on other sites More sharing options...
