BF turbo help
joshua1396
  • Member For: 8y 5m 18d
Hi all,
So I recently picked up a Manual BF MK2.5 XR6T with 140000 on the clock. While I know this is high kms it was a good price which I couldn't resist. I have a few questions regarding the naintainenece etc.
1. I'm going to do a full service of the car soon (oils, fluids, filters etc) so what would be recommended on a turbo of this age? The gearbox is a bit sticky so I'm going to do a service on that.
2. How can I check the health of the engine? I don't want to give it a bootfull until I know how healthy it is.
3. Is it true that the bf mk2.5 engine has similar internals to the typhoon engine? If so what parts?
4. The gearbox is making a roll over noise (apparently common on these gearboxes) should I be worried or is this normal?
Thanks!
  • skids
  • Member For: 12y 1m 13d
  • Gender: Not Telling
welcome to the forum,
1. 10w-40 I used last, I think all good here long as its synthetic (cuz the turbo heats the f^ck out of it) and the last number is -40. might put in a 5w-40 next myself. used a ryco filter.
2. give it a boot after ya done the oil change and you've driven it normally for ten minutes to warm it up properly. cmon rip a skid, it's australia.
3. stronger rods and idk what else
4. lightning strike silver has the least maintenance. you better hope your car is this colour :)
  • Member For: 8y 8m 22d
140k is just run in.
Do your service. Change all the fluids and filters.
Fuel filter is on the left chassis rail under the back seat/rear door area. The bolts are a c u next Tuesday to get out. There's threads here on it. The rest are easy.
I use nulon full syn 10w40 and a ryco filter z516 is the one you want. I've got a k&n panel filter.
I highly recommend getting an aftermarket oil feed line for your turbo if it hasn't been done yet. Here's why
Plenty of kits floating about. I just picked one up for $110.
After you've done all that if you're still unsure take it to your local tuner and get them to check it out for you.
Where are you located?
Edited by ROB83R
