OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m 21d Gender: Male Location: Western Sydney Posted 21/08/16 06:05 AM Share Posted 21/08/16 06:05 AM By the time the factory sensor goes off you've done damage. If you use a decent gauge that has a high and low waring it will go off before the factory sensor does if it is set properly. Link to comment https://www.fordxr6turbo.com/forum/topic/92341-opinions-on-gauges/page/3/#findComment-1608464 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 27d Gender: Male Location: Perth Posted 21/08/16 03:08 PM Share Posted 21/08/16 03:08 PM The big advantage of cheap gauges is you can get 2psi for free. Hey Steve. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92341-opinions-on-gauges/page/3/#findComment-1608539 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 29d Gender: Male Location: Probably above atmospheric pressure Posted 21/08/16 04:48 PM Share Posted 21/08/16 04:48 PM Not only that, you get more as time goes on! I can hit 20 just free revving in neutral hahaha. Tried replacing the sender (electronic boost gauge) but same problem. Gauge/sender/tubes/wiring kit was about $60 on eBay (per gauge). My boost gauge is 100% useless now, it reads waaaaaayyyy off when driving and goes out of range in half a second if I get up it and just flashes at me. +1 that unless gauges are accurate and have the sound and warning light alarm they are really only good for glancing at now and then or looking fancy to others. I use the oil temp to remind myself not to beat up on it yet during warm up (takes about ten minutes driving to really get up to a decent temp - coolant dial is up in half the time so don't rely on that). Also to watch it on hot days if towing. Oil pressure I glance at now and then but it's secondary to temperature. Link to comment https://www.fordxr6turbo.com/forum/topic/92341-opinions-on-gauges/page/3/#findComment-1608540 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 5m 25d Gender: Not Telling Posted 22/08/16 01:20 AM Share Posted 22/08/16 01:20 AM http://www.ebay.com.au/itm/VDO-OIL-PRESSURE-SENDER-SUITS-80-PSI-AND-500-KPA-VDO-GAUGES-/221302733824?hash=item3386abbc00:g:LfAAAOSwqu9U6boK ? no idea what to buy. 1/4 or 1/8 thread no idea, this looks closest like the one that's fitted. Link to comment https://www.fordxr6turbo.com/forum/topic/92341-opinions-on-gauges/page/3/#findComment-1608559 Share on other sites More sharing options...
Krazy Kyle Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds Cruise Control 2,697 Member For: 14y 8m 2d Gender: Male Location: Work Posted 22/08/16 02:13 AM Share Posted 22/08/16 02:13 AM On 21/08/2016 at 5:05 AM, .Stripes. said: Hey Kyle tumblr is blocked for me at work, use another hosting platform...saves me having to use my phone to check stuff. kthanx Expand e 2 Link to comment https://www.fordxr6turbo.com/forum/topic/92341-opinions-on-gauges/page/3/#findComment-1608580 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,040 Member For: 10y 2m Gender: Male Location: Canberra ACT Posted 23/08/16 11:15 PM Share Posted 23/08/16 11:15 PM On 22/08/2016 at 1:20 AM, johnxr6t said: http://www.ebay.com.au/itm/VDO-OIL-PRESSURE-SENDER-SUITS-80-PSI-AND-500-KPA-VDO-GAUGES-/221302733824?hash=item3386abbc00:g:LfAAAOSwqu9U6boK ? no idea what to buy. 1/4 or 1/8 thread no idea, this looks closest like the one that's fitted. Problem is the resistance of the sender has to match the gauge. Having said that, sometimes they still work and you are probably more interested in the gauge reading relative to where it normally sits rather than the absolute value of the reading. So if the wrong sender gave you a high reading for example, that doesnt really matter once you learn where the gauge normally sits and therefore notice when it deviates from this. Link to comment https://www.fordxr6turbo.com/forum/topic/92341-opinions-on-gauges/page/3/#findComment-1608796 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m Gender: Male Location: Perth Posted 24/08/16 01:44 AM Share Posted 24/08/16 01:44 AM ^whs. Also, Install your gauges so the needle points directly up when everything is "normal" 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92341-opinions-on-gauges/page/3/#findComment-1608815 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 5m 25d Gender: Not Telling Posted 24/08/16 02:18 AM Share Posted 24/08/16 02:18 AM I hate these gauges but have no idea what they are. oil pressure goes upto 150psi (not visible in image). the point of posting is maybe somebody might know what brand these are: On this image it really does look like that crimp terminal is not connected properly....I swear its pushed on as far as it'll go but might go have a play with it when I've got some more time. Link to comment https://www.fordxr6turbo.com/forum/topic/92341-opinions-on-gauges/page/3/#findComment-1608819 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 27d Gender: Male Location: Perth Posted 12/12/16 02:23 PM Share Posted 12/12/16 02:23 PM Spoke to SS inductions. Production on the triple pods is about to start. Should be available early next year, http://www.ssinductions.com.au/product_images/x/187/DGH008Parts__40239_zoom.jpg Link to comment https://www.fordxr6turbo.com/forum/topic/92341-opinions-on-gauges/page/3/#findComment-1625157 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 29d Gender: Male Location: Probably above atmospheric pressure Posted 12/12/16 02:48 PM Share Posted 12/12/16 02:48 PM People have been saying they are looking all over for them, that should please a few people! Link to comment https://www.fordxr6turbo.com/forum/topic/92341-opinions-on-gauges/page/3/#findComment-1625158 Share on other sites More sharing options...
