cat007 Member 236 Member For: 6y 8m 1d Posted 04/02/19 04:36 AM Share Posted 04/02/19 04:36 AM Haven't tried Torque app. Will do tonight! Will the free version work or do I need the full paid version?Do I add a custom PID or is it smart enough to do a scan?CheersHunt Link to comment https://www.fordxr6turbo.com/forum/topic/92294-best-location-for-an-external-transmission-cooler-fg-xr6t/page/8/#findComment-1673270 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 10y 13d Gender: Male Location: Canberra ACT Posted 04/02/19 05:05 AM Share Posted 04/02/19 05:05 AM Not sure if you need paid or not but is only a few bucks I think.Process is go to Settings, Manage custom PIDs, menu, Add a predefined set, Ford.When adding a gauge there will now be an option (Ford) Transmission Fluid Temp. You'll probably see a few, but if you are connected to your OBDII dongle you'll see live data, and one will look sensible as a Celsius reading. Link to comment https://www.fordxr6turbo.com/forum/topic/92294-best-location-for-an-external-transmission-cooler-fg-xr6t/page/8/#findComment-1673281 Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 8m 1d Posted 04/02/19 08:33 AM Share Posted 04/02/19 08:33 AM Howdy.Tried uwing Torque app adding the trans temp. There were 3. Two of which gave no reading and one gave a minus 40C reading, increasing to minus 35C as it warmed up while the car idled.Weird. Link to comment https://www.fordxr6turbo.com/forum/topic/92294-best-location-for-an-external-transmission-cooler-fg-xr6t/page/8/#findComment-1673307 Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 8m 1d Posted 04/02/19 09:16 AM Share Posted 04/02/19 09:16 AM This is the settings for the PIDAre these wrong? Link to comment https://www.fordxr6turbo.com/forum/topic/92294-best-location-for-an-external-transmission-cooler-fg-xr6t/page/8/#findComment-1673324 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 10y 13d Gender: Male Location: Canberra ACT Posted 04/02/19 09:52 AM Share Posted 04/02/19 09:52 AM Method 2 is the one you want. For some reason in the configuration it says F rather than C, but displays as C when you add a display. Link to comment https://www.fordxr6turbo.com/forum/topic/92294-best-location-for-an-external-transmission-cooler-fg-xr6t/page/8/#findComment-1673334 Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 8m 1d Posted 12/02/19 11:49 AM Share Posted 12/02/19 11:49 AM Thanks. Got it working.Any suggestions on a vent/louvre for the inner guard to vent the fans hot air when you mount the trans cooler under the drivers headlight, inside the bumper space?Bunnings has a crap selection. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92294-best-location-for-an-external-transmission-cooler-fg-xr6t/page/8/#findComment-1674026 Share on other sites More sharing options...
HOTXR6T Donating Members 58 Member For: 6y 9m 16d Gender: Male Location: SA Posted 15/06/19 12:28 PM Share Posted 15/06/19 12:28 PM I am researching before I install a trans cooler. The common place seems to be behind the right hand fog light area. A lot of comments are about heat, my air intake for the motor sits on the other side of this guard. Seems pretty obvious that if the guard is hotter the intake box is hotter. I know I will get the typical "thousands of people with bigger power than you have done it " responses. But plenty of people were doing mods years ago that they wouldn't do now. Has anyone done any testing on the intake box temperature with and with out the trans cooler? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92294-best-location-for-an-external-transmission-cooler-fg-xr6t/page/8/#findComment-1685313 Share on other sites More sharing options...
