  • Member For: 8y 11m 15d
  • Gender: Not Telling
I used 6 metres of hose and a 5/8 male/male hose connector to delete the exchanger.
I also added about 500ml of liquid gold to top up the fluid.
My trans temps are the same as coolant temps and the car runs as per normal.
  • flame magnet
  • Member For: 16y 11m 18d
im running a fan on my trans cooler too- the things so damn noisy though. thinking of putting a temp sensor module on it to turn it on and off.
is that a good idea? or is it just best to be on all the time. my BTR needs all the help it can get to stay in one piece...
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 25d
figure out why it's so noisy and replace the fan/fan-parts with not-as-noisy parts?
  • Dropping a turd
  • Member For: 17y 6m 8d
Expand
Have it come on at 70-80c.
Your exhaust and fuel pump must be crap if you can here a fan. Need to drill holes in the muffler
  • Moar Powar Babeh
  • Member For: 19y 7m 12d
Expand
  On 06/09/2016 at 12:32 AM, Rab said:
Is it a fairly old school fan? I can't hear the fan on my cooler when the cars idling (is a curved multi blade fan so pretty quiet)
No real value in leaving it running all the time. If I was you I'd certainly add a switch to control cut in/out for the fan
Expand
"Rab" is actually me.....
  • Bronze Donating Members
  • Member For: 11y 1m 8d
Just to throw my 2cents in- my brack ground is in lpg cars. In ba,s with radiator cooling we had no troubles with water flow to gas convertors. Then came bf,s .Gas convertors freezing up for no apparent reason - systems flushed, thermostats changed, water pumps replaced, heat exchangers replaced - all to no avail        (these are btr  e-gas) After market coolers fitted in front of radiator (water bypassed & heat exchanger ditched) -water flow & no more freezing. Problem solved (or so we thought) Enter fg,s ford picks up water for the convertor through a new spot above the water/air trans cooler No more convertor water flow problems. Now we have cabs coming with -trans over heat- on dash Guess what -no water flow to heat exchanger. Old faithfull trans cooler in front of radiator (and another trans) & back to work they go. So what I'm saying is don't trust that you will have water available to cool your trans fluid!
  • flame magnet
might be an old davies craig unit- sounds like its going to take off. what type of temp switch should I use- the ones with the temp probe that goes in the fluid line? or put a T inline for an engine temp type switch?
  • Moar Powar Babeh
I use one of these-
Came with my Kit.
http://www.ebay.com/itm/DERALE-8-AN-Inlet-Outlet-Temperature-Switch-Kit-P-N-35021-/331890592933
or
https://www.amazon.com/Derale-15721-Line-Fluid-Thermostat/dp/B000A8MWL2
VPW should have them. Derale also do an adaptor fitting that has barbs either end so you just chop the cooler outlet hose install the fitting and your done.
The say you can run the fan current through it but I'm not comfortable with that so it switches the earth on the control side of the relay I use to activate the fan.
  • Like 3
  • 1 year later...
  • New Member
  • Member For: 6y 10m 15d
  On 10/08/2016 at 6:51 AM, JETURBO said:
I did a bunch of R&D years ago and found beyond a doubt that behind the drivers fog light is perfectly fine location addressing all of your concerns
ive installed countless systems now with not a single issue or failed ZF yet , but this is with my method and installation
here's some of my recent ones
Expand
Would it not work on the other side closer to to the trans lines ?
  • XR50T
  • Member For: 12y 3d
Washer bottle is in the way on that side.
If your keen to move it as well it would work.
