  • Moar Powar Babeh
  • Member For: 19y 7m 11d
Generally not suitable for turbos due to clearance issues with the rad/intercooler.  Non of the off the shelf kits will give you enough hose for a behind the fog light mount.
  • Moar Powar Babeh
Personally I buy the cooler and fittings and spec my own hose. I've done 3 of the Mega cools (inc my own car) and all up it'll run you 5 to 6 hundred by the time it's installed but I don't think you can go past it for the combo of size/quality/performance.
  • Member For: 13y 8m 9d
Definitely looks the heaviest duty: biggest, thickest core, plus the big Fan.
Furious performance do a similar kit using Teflon braid and PWR core:
http://www.furiousperformance.com.au/retail_catalogue/TCK-FURFALCON_item.html?ref_cat_id=Coolmaster-Trasnsmission
$850 and thinner core compared to yours.
Edited by Ale
  • Moar Powar Babeh
that's a good price considering braided hose and fittings etc included.
If I was paying retail for parts I doubt I'd be able to get it any cheaper.
  • Dropping a turd
  • Member For: 17y 6m 7d
If your going to fit a cooler with fan, may as well fit one that is thicker for extra cooling, seeing it wont have natural air flow. Stock is 19mm, these are 32mm and come in 2 sizes. I use one as my engine oil cooler. Its similar to ralphs one. Fan draws air.
You could always install it here.
Edited by arronm
  • Member For: 12y 8m 2d
Another option is the PWR replacement oil/coolant heat exchanger unit. It seems to be a really nice bit of kit and no mucking around with wiring or running oil lines etc.
