Johnmal Member 39 Member For: 8y 5m 25d Posted 08/08/16 09:03 AM Share Posted 08/08/16 09:03 AM Hi, I might have asked this before however I'm not getting many answers about changing the transmission cooler in order for it not to fail causing the FG milkshake effect and costing thousands in damage, has the problem beign fixed on 2012 FG MKII or should I spend $600-$700 wasting my money on something that isn't an issue anymore. Of course the transmission mechanics say yes better upgrade for the peace of mind, what should I do. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 7d Gender: Male Location: Probably above atmospheric pressure Posted 08/08/16 09:31 AM Share Posted 08/08/16 09:31 AM No it was never fixed. The only 100% sure way is to avoid any sort of heat exchanger system (engine coolant and gearbox oil pass through the same block - which rusts out if you are unlucky). This means going to an air cooler (radiator) with a fan mounted on it. Personally I use the PWR heat exchanger to keep it as factory as possible - but have heard these can degrade too if you have a bad earth problem on the car so they aren't foolproof. :( 1 Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 4m 26d Gender: Male Location: Southern Highlands NSW Posted 08/08/16 11:09 AM Share Posted 08/08/16 11:09 AM You started a very similar topic the other day which has been replied to. Might be an idea to check there first before starting a new topic. http://www.fordxr6turbo.com/forum/topic/92272-transmission-cooler/#comment-1606255 1 Link to comment Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 8y 8m 12d Gender: Not Telling Location: Radioactive wasteland Posted 08/08/16 11:11 AM Share Posted 08/08/16 11:11 AM External air to oil cooler is the go. Some use fans some don't. If you're going to do track days you'll need a fan but otherwise no. I'm picking mine up this week and I've been spying setups on here and @JETURBO has a proven setup that I'll be trying to replicate. My kit is costing me $150 not including fluid. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,185 Member For: 16y 9m 22d Gender: Male Location: Melbourne Posted 08/08/16 01:10 PM Share Posted 08/08/16 01:10 PM 2 hours ago, RHR said: You started a very similar topic the other day which has been replied to. Might be an idea to check there first before starting a new topic. http://www.fordxr6turbo.com/forum/topic/92272-transmission-cooler/#comment-1606255 Hi Robbo Link to comment Share on other sites More sharing options...
