  • Member For: 9y 8m 15d
  On 11/08/2016 at 2:49 AM, Ralph Wiggum said:
I can arrange the purchase if you can arrange frieght.
Sweet I shall look into freight, Thank you!
  • Moar Powar Babeh
  • Member For: 19y 6m 24d
  On 11/08/2016 at 2:50 AM, tazzanz said:
Just to be clear, when I swap out block or even swap out rods. What do I need to change, Rings, Head studs, Head Gasket, + the other gaskets, Bearings?
Expand
How long is a piece of string? Depends on what you want to achieve Power wise.
I'm just meaning consumables no upgrades. Wish this engine builder would hurry up with this quote though!
  • Moar Powar Babeh
well consumables such as headbolts v headstuds would be determined by final power goals.
  • Moar Powar Babeh
For an FG Short install, budget for the motor $3.1K + freight (3.1K was landed in Perth so if they are able to do ex melb it may be cheaper, but knowing my parts guy he would arrange it to be transported on a stock transfer)
Top end Gasket Kit (head gasket/rocker cover gaskets/seals/intake exhaust gasket) $500
Sump U seals and Sealant $50
Fluids?? Depends on choice/preference $150 to $ 250
As for the head stud bolt/stud option. If your plans are to max a stock turbo on P98 use Gen Stock Bolts. If you have E85 plans it's worth installing studs.
Note you cannot reuse to original bolts
Im assuming your cylinder head is in good nick and doesn't require any work otherwise that'll quickly swallow 1k
  • Like 3
  On 11/08/2016 at 4:56 AM, BAXRTUTE said:
Do it once do it right,
I know the other way all to well....
Kicking stones sucks
Yea I saw your post, What would you do F6 short or build current?
