Mac0892 Member 72 Member For: 12y 6m 24d Gender: Male Location: Adelaide Posted 06/08/16 08:14 AM Share Posted 06/08/16 08:14 AM Hey guys, just looking for a quick answer here. Currently have a set of FPV argent replicas on my car and noticed that the RHR rim has a large crack on the inner edge down to the lip and running in line with the wheel. Getting it repaired on Tuesday but don't want to run around on a repaired rim for too long (not a fan of them) Looking for a new set of rims for my car and I'm wondering if a set of 19X8.5's would fit all round on a BF XR6T without having to roll the guards. For reference, wheels im currently looking at are the stance sc-5ive's or the stance sc-6 which both come in size mentioned above, but I believe the argents are 19X8.0. would that 0.5 make a difference? Link to comment https://www.fordxr6turbo.com/forum/topic/92268-bf-rim-sizing-question/ Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 9y 19d Posted 06/08/16 09:07 AM Share Posted 06/08/16 09:07 AM Whats the offset? If its around the +35 u should be sweet and will just fill the gaurds a little bit more. Link to comment https://www.fordxr6turbo.com/forum/topic/92268-bf-rim-sizing-question/#findComment-1606183 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 8y 11m 18d Gender: Not Telling Location: Radioactive wasteland Posted 06/08/16 09:35 AM Share Posted 06/08/16 09:35 AM Thread jack but could be informative. From what I've read the lower the number the more they fill out the guards? I was looking at a set of 20's at +25. They would rub the guards hard wouldn't they? Link to comment https://www.fordxr6turbo.com/forum/topic/92268-bf-rim-sizing-question/#findComment-1606188 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 11y 11m 12d Gender: Male Location: NOR Perth Posted 06/08/16 09:59 AM Share Posted 06/08/16 09:59 AM ^^ I think you might just be ok with this. Think its the 8.5 +35 that just rubs at full lock (with 245/35 and SSL or lower springs). But not 100% cause havent experienced first hand. Might have been MattyP who mentioned it?OP. OEM rims are 19x8 +36.5 offset. Go on willtheyfit.com and you can see how much it moves and what suits your level of flushness. Id go 19x8.5 +25 for nearly flushness. Could go anywhere between +10 to +35 depending how tucked you want it. If you're sticking to oem 245s all round. Be a baller and go 19x9.5+22 F&R. Shouldnt need roll...just depends how low it is. Link to comment https://www.fordxr6turbo.com/forum/topic/92268-bf-rim-sizing-question/#findComment-1606189 Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 9y 19d Posted 06/08/16 10:06 AM Share Posted 06/08/16 10:06 AM ^^ haha this guy 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92268-bf-rim-sizing-question/#findComment-1606193 Share on other sites More sharing options...
Mac0892 Member 72 Member For: 12y 6m 24d Gender: Male Location: Adelaide Posted 08/08/16 01:29 AM Author Share Posted 08/08/16 01:29 AM That concerns me with what you say there nitro. I have 245/35r19s at the moment with ssl's on the front and rear. Havent gotten any guard rub yet but the new rims apparently are +35 offset so, going by what you said, they may rub. Is it an easy job to roll guards these days? Link to comment https://www.fordxr6turbo.com/forum/topic/92268-bf-rim-sizing-question/#findComment-1606361 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 11y 11m 12d Gender: Male Location: NOR Perth Posted 08/08/16 06:24 AM Share Posted 08/08/16 06:24 AM nah you will be sweet. I had to reread your OP, but you're only going 1/2" wider and now you're saying +35, which is only 1.5mm off from the OEM offset. so 19x8.5 +35 with 245/35/19 all round will not scrub....safe as houses as they say Link to comment https://www.fordxr6turbo.com/forum/topic/92268-bf-rim-sizing-question/#findComment-1606396 Share on other sites More sharing options...
Mac0892 Member 72 Member For: 12y 6m 24d Gender: Male Location: Adelaide Posted 08/08/16 08:03 AM Author Share Posted 08/08/16 08:03 AM Do you reckon much would change if I threw some 235/35 19's at it? Im god awful when it comes to math. And I tried the 'will they fit' website and got slightly confused Link to comment https://www.fordxr6turbo.com/forum/topic/92268-bf-rim-sizing-question/#findComment-1606408 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 13d Gender: Male Location: Probably above atmospheric pressure Posted 08/08/16 09:13 AM Share Posted 08/08/16 09:13 AM On 08/08/2016 at 1:29 AM, Mac0892 said: Is it an easy job to roll guards these days? Expand Phone book and hair dryer is all you need according to some videos I've seen hahaha Link to comment https://www.fordxr6turbo.com/forum/topic/92268-bf-rim-sizing-question/#findComment-1606420 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 11y 11m 12d Gender: Male Location: NOR Perth Posted 08/08/16 09:16 AM Share Posted 08/08/16 09:16 AM I use 1010 tires for tyre change calcs: http://www.1010tires.com/Tools/Tire-Size-Calculator According to that the difference between 245 and 235 is 1.08%. So your speedo will read a little higher (at 100kmh your speedo will say 101.8kmh). If it really concerns you, I beleieve Ford (or a tuner) can recalibrate the computer (PCM - is that what its called?). But if using tuner, cant remember if they need the sct controller (or if hp tuners can do it too?). Link to comment https://www.fordxr6turbo.com/forum/topic/92268-bf-rim-sizing-question/#findComment-1606421 Share on other sites More sharing options...
