MattyP MattyP Cruise Control 6,317 Member For: 12y 9m 25d Gender: Male Location: Central Coast Posted 29/08/16 10:01 AM Share Posted 29/08/16 10:01 AM Wait what size turbine housing is on there? It's so disappointing to see when sh*t doesn't work out Link to comment Share on other sites More sharing options...
molch Donating Members 174 Member For: 18y 6m 29d Gender: Male Location: Central Coast Posted 29/08/16 10:11 AM Author Share Posted 29/08/16 10:11 AM (edited) 10 minutes ago, MattyP said: Wait what size turbine housing is on there? It's so disappointing to see when sh*t doesn't work out The exhaust turbine is 1.05 AR which, from what I now understand is one factor to compare against he ford 1.06 AR. However the design of the volute also has a huge effect so the numbers alone are not a good comparison. Edited 29/08/16 10:12 AM by molch Link to comment Share on other sites More sharing options...
Ale Member 249 Member For: 13y 6m 3d Posted 29/08/16 12:58 PM Share Posted 29/08/16 12:58 PM Stick with it man, you will be rewarded, I lot can be said about guys who take a shot, learn a lot and come out the other end achieving greatness. Again, I suggest you seriously look at a good quality 40mm external gate over more flapper mods. We used to mess around with actuators and extra springs on ported internal gates in 2002, until we manned up and worked out internal gates are rarely the optimum solution on high performance applications. Don't see internals on any formula one cars do ya!! 1 Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 3m 4d Gender: Male Location: Perth Posted 29/08/16 09:53 PM Share Posted 29/08/16 09:53 PM Up the boost.Big turbo & Small gate - high boost is one way to bandaid the issue.Big turbo & big gate - low boost / high boost will have no dramas for boost control Link to comment Share on other sites More sharing options...
courtjesterau New Member 19 Member For: 8y 6m 18d Posted 31/08/16 03:16 AM Share Posted 31/08/16 03:16 AM (edited) I am looking at buying a Mamba turbo as well I am considering the one you just got ( well maybe not now) and their GTX3576R here: http://www.ebay.com.au/itm/182261589403?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT is the spool / lag much more noticeable than the stock turbo with the one you have picked? Do you think the GTX3576R from Mamba will get to 380RWKW on pump 98 as that is all I am after. Edited 31/08/16 03:17 AM by courtjesterau Link to comment Share on other sites More sharing options...
Ale Member 249 Member For: 13y 6m 3d Posted 31/08/16 04:17 AM Share Posted 31/08/16 04:17 AM Silly question, but at $1300, does it work out that much cheaper than to rebuild ones factory core , and machining the comp cover to take a billet wheel from one of the suppliers? At least that way you keep the genuine core and rear wheel/housing. I wouldn't think the bigger 0.7 comp cover makes all that much difference on such small front wheels anyway. I was quoted less than $800 for a GTX wheel transplant into a genuine perfect condition GT35r that's done sub 5000km on another car of mine (not falcon) This was by ATS here in Adelaide and I think MTQ where similar. Link to comment Share on other sites More sharing options...
courtjesterau New Member 19 Member For: 8y 6m 18d Posted 31/08/16 11:07 AM Share Posted 31/08/16 11:07 AM 6 hours ago, Ale said: Silly question, but at $1300, does it work out that much cheaper than to rebuild ones factory core , and machining the comp cover to take a billet wheel from one of the suppliers? At least that way you keep the genuine core and rear wheel/housing. I wouldn't think the bigger 0.7 comp cover makes all that much difference on such small front wheels anyway. I was quoted less than $800 for a GTX wheel transplant into a genuine perfect condition GT35r that's done sub 5000km on another car of mine (not falcon) This was by ATS here in Adelaide and I think MTQ where similar. for a few hundred more I can get a brand new complete turbo and have the original one as a spare (or sell it) I was trying to decide between the 3584 and 3576 but after reading this thread im probably going to go the 76 Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 9m 25d Gender: Male Location: Central Coast Posted 31/08/16 11:14 AM Share Posted 31/08/16 11:14 AM WHS^ a complete gt3540 is worth at least 800ish with rear housing. Link to comment Share on other sites More sharing options...
molch Donating Members 174 Member For: 18y 6m 29d Gender: Male Location: Central Coast Posted 01/09/16 01:02 PM Author Share Posted 01/09/16 01:02 PM On 8/31/2016 at 1:16 PM, courtjesterau said: I am looking at buying a Mamba turbo as well I am considering the one you just got ( well maybe not now) and their GTX3576R here: http://www.ebay.com.au/itm/182261589403?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT is the spool / lag much more noticeable than the stock turbo with the one you have picked? Do you think the GTX3576R from Mamba will get to 380RWKW on pump 98 as that is all I am after. I got some time to drop in and chat with Spiro today @ Autotech today. The guys a legend. He explained the issue with the Mamba exhuast housing that the wastegate hole comes with a 90 degree corner in it. Typical housings would have a nice flowed bend. We agreed we are going to pull it off and get it inspected for another opinion and see if further internal porting can fix the issue. Would I buy a Mamba 3584R turbo again? Hard to say because I bought it as a drop in replacement to keep costs down etc and its not turning out that way so didn't really meet my initial requirements. Now I'm not saying to turbo compressor or core is bad (Jury is out) but my current learning is the exhaust housing is not ideal. For a drop in replacement the GTX3576r will be better I reckon (Budget for new intake pipes because its 4") . However the total power will depend on tuner, dyno, supporting mods and boost levels. This map shows it's doable but would need around 2.5 pressure (22PSI). To reliably get this high boost levels you also might have to port and exhaust housing so you could be in a similiar situation. Link to comment Share on other sites More sharing options...
Ale Member 249 Member For: 13y 6m 3d Posted 02/09/16 12:59 AM Share Posted 02/09/16 12:59 AM what am I missing in regards to using the original factory exhaust housing off your car? Link to comment Share on other sites More sharing options...
