Willturba New Member 9 Member For: 8y 8m 4d Posted 26/07/16 05:52 PM Share Posted 26/07/16 05:52 PM So my 2003 ba mk1 turbs spools up and pulls well till about 4-4500 grand than feels as if it hits a wall drops boost n barely runs (like an ecotec after its eco boost) starts jumping around an stalling but if I go nutreul and up revs comes good again n stop carrying on (like cammed LS) to my knowledge id say fuel issue starving for it but its pure stock so nothing is under powered at all.... gonna start fuel filter and hope its a cheap and easy fix (like charlie sheen) an praying to lord jesus that's its not the pump cause "ain't nobody got time for that" just curious if anyone else has had this issue if so what was it and can you remember prices Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 8d Gender: Male Location: Perth Posted 26/07/16 09:42 PM Share Posted 26/07/16 09:42 PM Valve springs and/or coils and plugs. Link to comment Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 8y 11m 13d Posted 26/07/16 10:06 PM Share Posted 26/07/16 10:06 PM ^ whs Change all 3 with a set of injectors fuel pump and whatever cheap cooler u can find then tune. U wont hit much over 250rkw unless u want to offload 7+k with all the little things that help em get to 300rkw. The BAs are a pretty average block so need heaps of help to get up to 300+rw Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 8d Gender: Male Location: Perth Posted 26/07/16 10:38 PM Share Posted 26/07/16 10:38 PM Umm...you don't need to spend 7k to make 300rwkw in a Ba. You just need the right parts in the right places installed and tuned by the right tuner. 2 Link to comment Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 8y 11m 13d Posted 26/07/16 10:55 PM Share Posted 26/07/16 10:55 PM Vavle springs 1k Injectors 3-500 Pump 500 Cooler 1-3k Intake 3-500 Flapper/porting 500 Dump cat Zorst 1k-1500 Tune 500 Xcal 500 If auto trans cooler 300 Then the 10 other little things that come along the way. 7k was a rough estimate but can be done for less but. Link to comment Share on other sites More sharing options...
Willturba New Member 9 Member For: 8y 8m 4d Posted 26/07/16 11:52 PM Author Share Posted 26/07/16 11:52 PM Plazmaman valve springs heavy duty - 2501000lb injectors - 200 500lh pump - 317Stage 2 plazmaman cooler - 1900Plazmaman cold air - 300Already own sct xcal3 so just 480 for tuneBut anyway coils n sparks are fresh n its starving for fuel when it hits the wall I'm dyslexic and cannot turn off simple functions in tapatalk Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 1m 19d Gender: Male Location: SW Sydney Posted 27/07/16 12:05 AM Share Posted 27/07/16 12:05 AM (edited) On 26/07/2016 at 11:52 PM, Willturba said: Plazmaman valve springs heavy duty - 250 plus 500-550 install 1000lb injectors - 200 lolwut Bosch/ID/KPM 1000cc injectors: 600-650 + 100 install 500lh pump - 317 self install? Stage 2 plazmaman cooler - 1900 assume self install Plazmaman cold air - 300 assume self install Already own sct xcal3 so just 480 for tune rule of thumb you get the tune you pay for...700 minimum for a proper custom tune by someone who knows these cars properly Expand ^^FTFY you might want to check your facts and figures again mate Edited 27/07/16 12:05 AM by camo86T 1 Link to comment Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 8y 11m 13d Posted 27/07/16 12:32 AM Share Posted 27/07/16 12:32 AM (edited) ^ this guy! If u can get valve spring fitted for under $800 your winning right there... 99.9% of tuners charge $900+gst Are u fitting most things urself Willturba? Also u say the coils are new? Are they genuine ford? Or vdo? Or something else? Edited 27/07/16 12:39 AM by BAXRTUTE Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 3m 3d Gender: Not Telling Posted 27/07/16 01:29 AM Share Posted 27/07/16 01:29 AM ^or buy the whole car with ~360kw for $6500. Using VDO coils here and runs just fine. Okay it's cost me close to $12k including tyres n insurance... Ralph is most likely correct on this matter anyway and I would start by following his advice. My only suggestion is maybe the fuel pump sock in the tank is clogged - but didn't think that was too much of an issue for stock cars. Link to comment Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 8y 11m 13d Posted 27/07/16 02:15 AM Share Posted 27/07/16 02:15 AM Definitely sounds like valve springs, mine cut at about 4500rpm as well and felt exactly like his described. Got the atomics in these days Link to comment Share on other sites More sharing options...
