  • Moar Powar Babeh
  • Member For: 19y 7m 29d
No claws is effective for removing sound from speakers, not reinstalling it.
  • Moar Powar Babeh
  On 12/07/2016 at 7:28 AM, Ralph Wiggum said:
Flash the stock tune back into it (but don't start it) and see if it works.
Then revert to the correct custom tune obviously.
I'll have a look at the sync 2 in wifeys TT tonight as see if I can spot and obscure reason why it would do that.
Expand
  On 12/07/2016 at 7:36 AM, mightbuyaford said:
load standard tune and check. Make sure you re-load the modified tune back into it before running your car though....
if it works back on the standard tune then call the tuner and get him to fix it otherwise off to ford for a ICC reset/update
Expand
/keith
  • Member For: 15y 1m 17d
Thanks- I will flash the stock tune back in tomorrow and see what happens. It has had injectors swapped so I will definitely not be starting the car. I keep you posted.
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 12d
:idunno:It's possible that they'll not care and it's also possible they'll screw you over. Only 1 way to find out.
  • Member For: 22y 1m 22d
Back in 2012 I took my FG to get the aircon module updated (had aircon probs and needed codes). I told the service guy that the car was flashed and put a note on the dash.  I heard a car splutter into life from the waiting area and idle like a pig. Then the service guy comes out and says the tech guy accidently updated the whole car as it was on auto update.
In the end they were able to restore it to the original tune (don't know how they did that and he was very worried if they could restore it cause he said I may need a truck) but you got to bear this in mind whenever getting updates on a tuned car.
Edited by turbotrana
Problem resolved. It was not an ICC issue at all. The stereo system runs through an Audison Bit One sound processor. Somehow the flash tuning process interfered with the sound processor. The processor needed to be reset and the audio tune file reinstalled. All Good. Thanks to all.
  • Site Developer
nice of you to mention that you had aftermarket audio components...
good on ya for getting it sorted, anyway :spoton:
