Brendon Wrigley New Member 17 Member For: 9y 1m 20d Gender: Male Location: Rockhampton QLD Posted 11/07/16 06:14 AM Share Posted 11/07/16 06:14 AM Hi Guys, Very intermittently I get the ABS and traction control light coming on. I've looked up and read a few remedies peopel have tried. Clean the ABS wheel sensor, check brake lights etc. mine is very intermittent, only comes on after I start driving come on at either 25km/h or 60km/h ish. I might be on for one trip (or just turn the car on and off again mid trip) then off for a week, or it has also been on for every trip for a week or so then off again for a week then back on for a couple of days. my mates has but his snap on scan tool on it. its error code C1278 which is steering wheel angle sensor... it had a wheel alignment before I picked it up, could it be something to do with that? Link to comment Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 8y 7m 26d Gender: Not Telling Location: Radioactive wasteland Posted 11/07/16 06:21 AM Share Posted 11/07/16 06:21 AM I have a similar issue. It just turns off after I hit 10km/h. I mean the traction light stays on as if I turned it off with the switch. If it's on and I turn a corner a bit hard I get the light flashing and front brakes pulsing. I dare say it's a steering wheel angle thing. You can pop the cover off the bottom of the column and check it. There's also a thread on here about it. that's it. This is for a falcon but it'll be the same thing I reckon. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 23d Gender: Male Location: Perth Posted 11/07/16 06:27 AM Share Posted 11/07/16 06:27 AM ^whs Where are you located? A steering angle sensor recalibration may help if the sensor isn't kaput. Link to comment Share on other sites More sharing options...
BLKPRL New Member 3 Member For: 12y 10m 19d Gender: Male Location: Auckland NZ Posted 11/07/16 06:32 AM Share Posted 11/07/16 06:32 AM Funny I saw this post. Mate of mine had the same symptoms on his FG Found it to be the brake pedal switch was faulty. Could be a good place to start and I hear it is a common problem. Cheers BP Link to comment Share on other sites More sharing options...
Brendon Wrigley New Member 17 Member For: 9y 1m 20d Gender: Male Location: Rockhampton QLD Posted 11/07/16 02:00 PM Author Share Posted 11/07/16 02:00 PM In rockhampton updated my profile now. Thanks guys I'll suss out these ideas Link to comment Share on other sites More sharing options...
Brendon Wrigley New Member 17 Member For: 9y 1m 20d Gender: Male Location: Rockhampton QLD Posted 04/05/17 01:22 AM Author Share Posted 04/05/17 01:22 AM Hey guys never ended up posting my fix. ended up being the ABS unit its self, replace it and fault went away and hasn't come back 1 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 7m 15d Gender: Male Location: Adelaide Posted 04/05/17 01:57 AM Share Posted 04/05/17 01:57 AM Thanks for posting the result buddy Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,139 Member For: 16y 9m 5d Gender: Male Location: Melbourne Posted 04/05/17 01:58 AM Share Posted 04/05/17 01:58 AM Link to comment Share on other sites More sharing options...
Packmeapipe New Member 4 Member For: 4y 19d Posted 31/12/20 10:49 AM Share Posted 31/12/20 10:49 AM (edited) my creader throws the same code but my t/c light doesnt turn on till I drive for about 20ish minutes, the creader also tells me my steering angtle at straight is ten degrees out (cars had a wheel alignment to this and drives dead straight with wheel slight tilt the people I bought it off had the alignment done) how do I run a calibration test im not sure if my creader does those? or is it simple enough to disconnect and rotate it myself and keep checking with the creader till its right? Edited 31/12/20 10:50 AM by Packmeapipe Link to comment Share on other sites More sharing options...
Draino Donating Members 69 Member For: 5y 4m 20d Gender: Male Location: NT Posted 06/05/24 01:04 PM Share Posted 06/05/24 01:04 PM Well hello there, dont mind me necro fellating this old thread. Anyone got an ABS module to suit a 2007 Territory Ghia Turbo for sale? I can't bleed my rear brakes 😞 Codes sorted.....I fear a proportioning valnve and/or booster cylinder might need replacing too,... Link to comment Share on other sites More sharing options...
