knowhereman Donating Members 107 Member For: 13y 7m 11d Gender: Male Location: Torquay, Vic Posted 10/07/16 11:19 PM Share Posted 10/07/16 11:19 PM Hey guys, I need to take my timing cover off my 04 Turbo. Only done 103,000kms. I will replace water pump and gaskets. I wanted to get advice, should I replace timing chain and tensioner guides while I am there? What sort of life is reasonable for these parts? Link to comment https://www.fordxr6turbo.com/forum/topic/92161-ba-xr6-turbo-engine-questions/ Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 7d Gender: Male Location: Adelaide Posted 10/07/16 11:26 PM Share Posted 10/07/16 11:26 PM If you plan on keeping the car , yes without a doubt not so much the chain but definitely the guides ultimately I would go the Atomic full timing HD"kit" comes with guides/Chain/tensioner/trigger gear it's always a slippery slope as then you may want to go pump gears/assembly also but this is kind of depending on how you drive your car it's expensive but heaps cheaper than a full engine if the stock stuff gives up on you buzz me a pm if you want a good price on a kit or full kit Link to comment https://www.fordxr6turbo.com/forum/topic/92161-ba-xr6-turbo-engine-questions/#findComment-1600197 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 15d Gender: Male Location: Maryborough Qld Posted 05/10/16 10:05 AM Share Posted 05/10/16 10:05 AM so. chsin guide and tendioner can be replaced easily with cover off and chsin still installed? my ba xr6t with 290 000k. has timing cover leak. is it good to replace guides at same time?? Link to comment https://www.fordxr6turbo.com/forum/topic/92161-ba-xr6-turbo-engine-questions/#findComment-1615296 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 15d Gender: Male Location: Maryborough Qld Posted 05/10/16 11:06 AM Share Posted 05/10/16 11:06 AM also.bi pulled down a spare n/a ba engine that had 120 000 on it. could I use the chain tensioner and guides from nit on mine seeing its done way less ks? Link to comment https://www.fordxr6turbo.com/forum/topic/92161-ba-xr6-turbo-engine-questions/#findComment-1615302 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 10d Gender: Not Telling Posted 05/10/16 11:14 AM Share Posted 05/10/16 11:14 AM if you've got the timing cover off you'd definitely want to replace the guides, get a whole timing kit actually! They're consumable items and something I wouldn't recommend re using. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/92161-ba-xr6-turbo-engine-questions/#findComment-1615303 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 15d Gender: Male Location: Maryborough Qld Posted 06/10/16 02:33 AM Share Posted 06/10/16 02:33 AM hmmm. dont really wanna change the chain. as that would be a headach...unless its easy? Link to comment https://www.fordxr6turbo.com/forum/topic/92161-ba-xr6-turbo-engine-questions/#findComment-1615359 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 10d Gender: Not Telling Posted 06/10/16 04:44 AM Share Posted 06/10/16 04:44 AM (edited) Man if the drug ffffed c*nt I bought my car off can do it, so can you Pretty sure once the tensioner /maybe the guides are removed (also in a timing kit) the chain would have enough slack to come off. Edited 06/10/16 04:44 AM by skidxr6t Link to comment https://www.fordxr6turbo.com/forum/topic/92161-ba-xr6-turbo-engine-questions/#findComment-1615373 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 15d Gender: Male Location: Maryborough Qld Posted 07/10/16 09:15 PM Share Posted 07/10/16 09:15 PM (edited) hahahah. well I was.more saying if inhad to remove the gears would be a *beep* as knowing me id I I <3 Bananas up lol do the chains wear over time causeing enough slack to effect timming? it would be aomething id look into if I was to remove cover as I can get a timming kit for about 150 Edited 07/10/16 09:17 PM by jas98 Link to comment https://www.fordxr6turbo.com/forum/topic/92161-ba-xr6-turbo-engine-questions/#findComment-1615639 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 10d Gender: Not Telling Posted 07/10/16 10:20 PM Share Posted 07/10/16 10:20 PM The chain stretches over time, the plastic guides wear out and in the case of my engine, they snap. When the chain is stretched and the guides are worn out/snapped it can more easily jump teeth when the driver of the car is thrashing it. what I'm told is it seems to be when somebody is going at it hard and then quickly releases the throttle. In my cars case, old owner thought the bottom end had gone so removed the engine but found it was just the timing gear. luckily the engine seems to be going strong 6 months later. apparently mine didn't skip teeth, was just making a horrible noise. Link to comment https://www.fordxr6turbo.com/forum/topic/92161-ba-xr6-turbo-engine-questions/#findComment-1615642 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 15d Gender: Male Location: Maryborough Qld Posted 09/10/16 04:19 AM Share Posted 09/10/16 04:19 AM thanks ill definally look into it anyone use NASON timming kit for the xr6t? comes with tensioner guides and chain... Link to comment https://www.fordxr6turbo.com/forum/topic/92161-ba-xr6-turbo-engine-questions/#findComment-1615789 Share on other sites More sharing options...
