XRBoost Member 50 Member For: 8y 11m 27d Gender: Male Posted 02/07/16 02:06 PM Share Posted 02/07/16 02:06 PM I had my discs machined about 2 or 3 weeks ago, had a nasty squeal when braking. Now it's starting to squeal again, not as bad as before but I'm surprised the pads have done the damage this quick. I've been told by a few xr6t owners that I would benefit greatly from slotted/dotted rotors. It was also suggested that a fresh pair of brembo pads will be beneficial although the pads in the brakes are relatively new. Should I go down the slotted rotor path? I wasn't going to until I pushed more power into it (BA xr6t with 235rwkw at the moment) at which point I'd go with brembo brakes plus slotted/dotted rotors. Was kinda keen on mods for power first, which would require me to upgrade the brakes and rotors anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/92125-should-i-upgrade-my-rotors/ Share on other sites More sharing options...
Guest Guests Posted 02/07/16 02:13 PM Share Posted 02/07/16 02:13 PM a set of T2 rotors and some decent pads will solve all your problems. Cant go wrong with an upgrade in the braking area http://www.ebay.com.au/sch/I.html?_from=R40&_trksid=p2050601.m570.l1313.TR12.TRC2.A0.H0.Xford+BA+t2.TRS0&_nkw=ford+BA+t2&_sacat=0 Link to comment https://www.fordxr6turbo.com/forum/topic/92125-should-i-upgrade-my-rotors/#findComment-1598894 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 3d Gender: Not Telling Posted 02/07/16 11:29 PM Share Posted 02/07/16 11:29 PM (edited) I'm running T2's that were already on my car which are due for replacement soon. They are brilliant however I'm throwing up between T3's on front with project mu pads or a deal I was offered for some brembos which has been screwing with my head cause I want them so badly. when I say the T2's are brilliant, my rotors are obviously nearing end of life and I don't have the slightest hint of brake shudder or any issues whatsoever. Edited 02/07/16 11:29 PM by johnxr6t Link to comment https://www.fordxr6turbo.com/forum/topic/92125-should-i-upgrade-my-rotors/#findComment-1598910 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 8d Gender: Male Location: Perth Posted 02/07/16 11:33 PM Share Posted 02/07/16 11:33 PM Brembo upgrade seems like a no brainer to me? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92125-should-i-upgrade-my-rotors/#findComment-1598911 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m Gender: Male Location: Adelaide Posted 03/07/16 01:09 AM Share Posted 03/07/16 01:09 AM ^^^ this ^^^ Link to comment https://www.fordxr6turbo.com/forum/topic/92125-should-i-upgrade-my-rotors/#findComment-1598914 Share on other sites More sharing options...
XRBoost Member 50 Member For: 8y 11m 27d Gender: Male Posted 03/07/16 11:10 AM Author Share Posted 03/07/16 11:10 AM On 02/07/2016 at 11:33 PM, Ralph Wiggum said: Brembo upgrade seems like a no brainer to me? Expand I understand the brembo brakes are the best of the best, but will the brembo brake pads suffice with new t2 rotors? Or save for t2 rotors and brembo bakes and pads? Link to comment https://www.fordxr6turbo.com/forum/topic/92125-should-i-upgrade-my-rotors/#findComment-1598999 Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 2m 5d Gender: Male Location: Perth Posted 03/07/16 12:22 PM Share Posted 03/07/16 12:22 PM If you can't afford brembos its not like they're essential. Are your rotors even warped or is it just the pads squeeling? Maybe you just need some different pads.. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92125-should-i-upgrade-my-rotors/#findComment-1599007 Share on other sites More sharing options...
XRBoost Member 50 Member For: 8y 11m 27d Gender: Male Posted 03/07/16 12:37 PM Author Share Posted 03/07/16 12:37 PM On 03/07/2016 at 12:22 PM, Lennox said: If you can't afford brembos its not like they're essential. Are your rotors even warped or is it just the pads squeeling? Maybe you just need some different pads.. Expand Rotors were recently machined but was advised not to machine again as they will get too thin. And the pads are brembo pads, almost brand new. Link to comment https://www.fordxr6turbo.com/forum/topic/92125-should-i-upgrade-my-rotors/#findComment-1599009 Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 2m 5d Gender: Male Location: Perth Posted 03/07/16 12:48 PM Share Posted 03/07/16 12:48 PM Soo.. are the rotors even warped or is it just the pads squeeling? Maybe they're just sh*t noisy pads or you've chucked track pads in there and what you really want is quiet street pads. .? Link to comment https://www.fordxr6turbo.com/forum/topic/92125-should-i-upgrade-my-rotors/#findComment-1599010 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 8d Gender: Male Location: Perth Posted 03/07/16 12:59 PM Share Posted 03/07/16 12:59 PM In all fairness, "Brembo Pads" are available for trucks/buses/trains/passenger cars etc etc so just because they are Brembo doesn't mean they are a performance pads. BTW my Brembo is the obvious solution was aimed at John. I have a spare set. He NEEDS a set so I was just poking fun. If you can get the PN of the pads it would make it easier to determine if the pads are the issue or not. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92125-should-i-upgrade-my-rotors/#findComment-1599011 Share on other sites More sharing options...
