ONOWAY New Member 2 Member For: 9y 10m 5d Posted 29/06/16 03:37 AM Share Posted 29/06/16 03:37 AM Hey peeps! how can I make my Fg turbo flutter, is it as simple as installing an aftermarket bov or is there more to it? Link to comment https://www.fordxr6turbo.com/forum/topic/92114-turbo-flutter/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,451 Member For: 17y 20d Gender: Male Location: Melbourne Posted 29/06/16 03:40 AM Share Posted 29/06/16 03:40 AM Flutter (tutututu sound - turkey gobble) = blocked BOV (no BOV) Typical Blow-Off (pssssshhhhtt sound) = vented to atmosphere BOV. Both can be done with the stock system. The sound (of either) is enhanced by bigger pipes, shorter pipes, more "open" intakes and more boost 2 Link to comment https://www.fordxr6turbo.com/forum/topic/92114-turbo-flutter/#findComment-1598184 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 6d Gender: Male Location: Probably above atmospheric pressure Posted 29/06/16 04:26 AM Share Posted 29/06/16 04:26 AM Yep, in short take out your factory BOV and plug all the pipes leading to it. 2x rubber chair leg end stoppers and a suitable sized bolt for the smaller vacuum hose Don't waste dollars on an aftermarket BOV unless you can get it as a trade for a carton of VB. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/92114-turbo-flutter/#findComment-1598190 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 26d Gender: Male Location: Central Coast Posted 29/06/16 05:16 AM Share Posted 29/06/16 05:16 AM What Steve said Block with rubber chair stoppers and be done with it Turbo side intake really helps Link to comment https://www.fordxr6turbo.com/forum/topic/92114-turbo-flutter/#findComment-1598195 Share on other sites More sharing options...
Hussydabomb Member 81 Member For: 10y 4m 7d Posted 29/06/16 11:32 AM Share Posted 29/06/16 11:32 AM If you block it off it does get a bit more of a flutter but you can go a step further and use 90 bend right up from the turbo and put a pod on it and that gets a mad long ass flutter sutututtutututututututut. I have also used an ba turbo plastic pipe the one that comes right off the turbo, cut it at half length and put a pod on that. It gets a really deep sounding flutter that goes for ages. Link to comment https://www.fordxr6turbo.com/forum/topic/92114-turbo-flutter/#findComment-1598254 Share on other sites More sharing options...
