luke187 Member 297 Member For: 11y 4m 24d Posted 29/06/16 05:38 AM Share Posted 29/06/16 05:38 AM (edited) Got my FG F6 motor apart and they're definitely a cast mahle piston, but they are different. I believe HI PSI said the same about his short motor when he got his, and also read an article recently by someone who a lead designer or something at FPV who also said they arent forged but a different heavier design and lower compression. Theres a BF into the 8's on stock cast turbo pistons so its not the weak point of the engine anyway. ... and mattyp is right. High comp turbo e85 is the only way to go! Edited 29/06/16 05:40 AM by luke187 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92105-engine-build/page/3/#findComment-1598201 Share on other sites More sharing options...
SipposBFT Member 81 Member For: 15y 8m 9d Posted 29/06/16 06:29 AM Author Share Posted 29/06/16 06:29 AM (edited) 51 minutes ago, luke187 said: Got my FG F6 motor apart and they're definitely a cast mahle piston, but they are different. I believe HI PSI said the same about his short motor when he got his, and also read an article recently by someone who a lead designer or something at FPV who also said they arent forged but a different heavier design and lower compression. Theres a BF into the 8's on stock cast turbo pistons so its not the weak point of the engine anyway. ... and mattyp is right. High comp turbo e85 is the only way to go! Great info luke ... Thankyou ... I do understand yr hi comp favouritism .... But I want to b able to run on 98 as well as possibly E85... My last car (r31 RB 30t ) was tuned on E85... Mainly cause the pistons used were too high to run on 98... In short was a pain as I had to travel out of my way to fill up... & as it's also my only set of wheels I also take long trips with her. Curious ... Did u buy the engine from a salvage yard or do u own an F6? If U bought how much? Edited 29/06/16 06:32 AM by SipposBFT Link to comment https://www.fordxr6turbo.com/forum/topic/92105-engine-build/page/3/#findComment-1598204 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 26d Gender: Male Location: Central Coast Posted 29/06/16 06:43 AM Share Posted 29/06/16 06:43 AM Benefits of living so close to e85 servos and everywhere I go there is an e85 servo (Kempsey for the inlaws, canbra for the family and several on the cenny coast) Im a lucky man, Also I think it is far more ethical to use e85 as its giving money to locals rather than sending it over to the saudis, it may cost a little more (alot more around town) but its worth it imo. Even if you need petrol add water injection and back the petrol tune way off until you can switch back to the jungle juice 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92105-engine-build/page/3/#findComment-1598207 Share on other sites More sharing options...
luke187 Member 297 Member For: 11y 4m 24d Posted 30/06/16 08:06 AM Share Posted 30/06/16 08:06 AM You find anyone with an off the shelf set of high compression forged pistons for the barra? Link to comment https://www.fordxr6turbo.com/forum/topic/92105-engine-build/page/3/#findComment-1598363 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 26d Gender: Male Location: Central Coast Posted 01/07/16 03:57 AM Share Posted 01/07/16 03:57 AM Yes I did Spool do a fullyforged piston But I picked up a set of mahle lpg pistons at 10.5 to 1 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92105-engine-build/page/3/#findComment-1598518 Share on other sites More sharing options...
luke187 Member 297 Member For: 11y 4m 24d Posted 07/07/16 08:37 AM Share Posted 07/07/16 08:37 AM On 7/1/2016 at 1:57 PM, MattyP said: Yes I did Spool do a fullyforged piston But I picked up a set of mahle lpg pistons at 10.5 to 1 Are the LPG pistons forged though? Saw some on ebay but they're cast like the f6 pistosn ive pulled from the car. Might get a phone call off to spool. Link to comment https://www.fordxr6turbo.com/forum/topic/92105-engine-build/page/3/#findComment-1599658 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 26d Gender: Male Location: Central Coast Posted 07/07/16 09:10 AM Share Posted 07/07/16 09:10 AM I dont think so They look cast but I'm not building an engine for 500kw Just want higher comp Should have just gone an ecolpi short block Link to comment https://www.fordxr6turbo.com/forum/topic/92105-engine-build/page/3/#findComment-1599661 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 11m 19d Gender: Male Location: Gold Coast Posted 06/01/17 01:49 AM Share Posted 06/01/17 01:49 AM Found this interesting on Atomic's site: Conrods and PistonsQ: Do I need to rebalance my engine if I fit Atomic conrods to my XR6-T? A: As the engine is an inline configuration, the conrod and piston weights are not a function of the balance factor of the engine (as they are in a V configuration engine), so they can be installed without rebalancing the engine. Link to comment https://www.fordxr6turbo.com/forum/topic/92105-engine-build/page/3/#findComment-1627566 Share on other sites More sharing options...
