FG F6 Mii 432rwkws 1080Nm's
blow off
  • Member For: 16y 6m 27d
Sold the Ute then got a St Focus, Great Little Car ! and in between found this FG F6 Mii.
Got it tuned by Dave (CPV Tuning) made 432Rwks and 1080Nm's on E85. 400 on Pump
Valve float when turning it up to 455.
Stock motor
mods:
Factory Turbo with porting + 12 psi Turbosmart actuator
Plazmaman intake, cooler, fuel system + rail
tog 4in zorst
1000cc bosh injectors
Battery relocation
Built Tail shaft
Going to do coilovers and replace the NT05's on the rear with R888's and hopefully leave it alone.
If the ZF fails will get the springs done too and turn it back up to around 460
Love the factory turbo compared to the GTX42 that was on the Ute.
http://th_P1030313_1.jpg
Edited by blow off
5 hours ago, blow off said:
Ha-Ha thanks for the comments..
The wheels are Work Rims 19x8.5 Fronts with a 30mm Spacer and Rears 10" offset 35
Edited by blow off
Will get them done when board for what it has now.. have to get a better fuel pump too, only running a 044 with Plazmaman Surge. After this the ZF will need some attention...
