Show us your PC and/or Gaming setup
k31th
  • WOT?
  • Moderating Team
  • Member For: 11y 11m 23d
Went yellow/lime liquid, with yellow UV tubing.
Am pretty sure it'll look pretty shocking, but wanted something that'd give me an idea of what to use moving forward.
The tube was cheap, so once everything's in place I can workout the layout and fittings required to goto hard tubing.
  • Feeling the Love :-)
  • Bronze Donating Members
  • Member For: 11y 10m 17d
remember my mistake?
make sure you buy twice as much hard tube as you think you need
you WILL make mistakes
white coolant would go well with your motherboard
  • WOT?
  • Moderating Team
Yeah - am thinking opaque white with clear tubing will be the end game.
Am going to throw a unicorn spew rainbow at it this round and see what sticks (RGB/UV light strips etc with the motherboards inbuilt RGB "enhancements")
Will try and make it look as bad as possible and work backwards til happy ;)
I have found that the best LED strips to use are white
It really helps to highlight your colour scheme
Just so long as you are satisfied with said scheme
  • WOT?
  • Moderating Team
Leak test
Bottom GPU leaked - o-ring on the connector didn't seat properly.
Does now.
All up and running
Unicorn poop:
UV is surprisingly effective
Temp seem great - 30's for CPU, 20's for GPU's (idle)
Late now - wrapped with the result so far.
Stress tests and benchmarks tomorrow(ish)
  • Like 3
  • Puff
  • Member For: 10y 19d
If you haven't already, download the latest beta version of afterburner.
Using the voltage curve (ctrl f) and also unlocking the voltage slider, I've been able to run my card over 2100MHz.
You should have no trouble getting there as mine is air cooled.
I'll chuck up some pointers on how to set it up if there is any interest.
4 hours ago, Rab said:
Unicorn poop:
those temps are fantastic Rab
and love the unicorn poop
hows the fan noise, barely audible ?
