Show us your PC and/or Gaming setup
k31th
  • Feeling the Love :-)
  • Bronze Donating Members
  • Member For: 12y 7d
  On 28/11/2019 at 11:00 PM, skidxr6t said:
Any thoughts on this as a replacement case:
https://www.ple.com.au/Products/636879/Lian-Li-PC-O11-Dynamic-XL-ROG-Certified-Full-Tower-Case---Black
Or alternative suggestions.
Expand
if you buy this case then you need this!!!!!!
https://www.pccasegear.com/products/48297/ek-classic-distro-plate-front-pc-o11d-d-rgb-with-spc-pwm
  • skids
  • Member For: 12y 3m 11d
  • Gender: Not Telling
the extra space at rear of motherboard is something im used to in current case. I have to accomodate a 240mm radiator that's 80mm thick.
just worried about airflow over the motherboard, don't want to take a step back from what I already have.
Does that distribution plate include a pump? it seems like it does but it's too small. I run a D5 pump with res on top.
Don't tempt me...... HA
is yours the larger version of this case?
Edited by skidxr6t
I bought this one
https://www.pccasegear.com/products/43082/lian-li-pc-o11-dynamic-tempered-glass-case-white
You can put up to 3 fans on the floor of the case blowing air up
So plenty of airflow over the mother board
I mounted my thick radiator inside the front chamber, with the fans in the back chamber blowing hot air out of the case
I don't think you will fit a thick radiator in the second chamber
Check out the video in the link above
Bottom line for me
I love how this case looks and accommodates everything you can throw at it
Function and form
  • skids
Expand
yeah....it's kinda got me bitten. Was happy using my current case until I saw it ❤️
I really need to go see one before buying it but local shop has not got one on display.
Am thinking of going hard tubing...have access to all the tools needed...just love how easy soft tubing is to work with.
Hard tubing is a little bit difficult but the struggle is totally worth it
I never used soft tube
Started with hard tube and in my opinion it looks soooooooooo much better
Expand
here is a couple of pics of the "second chamber" or the space behind the motherboard which is traditionally only about 30 to 40 mm
hope this helps with your decision
looking at the pic below, you can see the provision for a second power supply, Lian Li have thought of everything
  • 1 month later...
  • FREAKY
  • Member For: 15y 3m 14d
is anyone here switched on with tablets?
thinking about finally getting one for my daughter to use sparingly! but mostly for me n the mrs when on the couch and cbf firing up the pc.
want one with a data plan to use out n about in car etc.
  • skids
Expand
They've broken me with this case too! If I pulled the trigger I would go GPU block + two triple 120 radiators. Ran out of money after the 9900K upgrade though!
Hey has anybody measured power draw under load? I get about 100W idle and 400-450w under load. running 650w PSU. 9900K+2080.
Expand
I'm gonna sound like an apple fan but I can't go past the ipads, I still have the original ipad which is fully working and cannot say that about any android tablets I've owned. That being said you can get something far cheaper in android than apple... (edit: the ipad pro is crap, when I recommend apple ipad I recommend their cheapest model).
Edited by skidxr6t
Expand
just get the case and go from there
I paid $189, see its gone up $10 though
best $189 I've ever spent on a case  period!
bought THIS yesterday
finally get some RGB fans into the equation :nod:
going to also modify my tubing and make a dedicated fill port to make life a tad easier
Edited by bloodycrashboy
  • FREAKY
Expand
haha we are all android here, mum has an early I pad and its still going strong would be 10 years I think.
