El Andrew Gold Donating Members 2,040 Member For: 10y 1m 29d Gender: Male Location: Canberra ACT Posted 20/06/16 12:00 AM Share Posted 20/06/16 12:00 AM Hi everyone Anyone had this problem with a B series? Car was parked outside in heavy rain yesterday afternoon and last night and there was a massive lake in the rear driver's side footwell this morning. Car was parked on a slope, nose high, and tracing the water back it seems to be originating near the front edge of the front drivers door. Had the same problem about a year ago but to a lesser extent and it never recurred, so I assumed the door wasn't closed properly. Seals look ok and confirmed windows were up properly. Maybe a blocked duct or something in front of the windscreen? Any help appreciated! Fortunately I've got secure parking at work, so car is in basement with doors open until I can a hair dryer on it tonight. Pic is of where water starts in drivers footwell Link to comment https://www.fordxr6turbo.com/forum/topic/92084-water-leaking-into-footwear-not-ac/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,563 Member For: 17y 2m 10d Gender: Male Location: Melbourne Posted 20/06/16 12:02 AM Share Posted 20/06/16 12:02 AM I don't know how water could get there unless the seal around the door was not sealed (either actually open or break in the seal)... Link to comment https://www.fordxr6turbo.com/forum/topic/92084-water-leaking-into-footwear-not-ac/#findComment-1596412 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 28d Gender: Male Location: Perth Posted 20/06/16 12:34 AM Share Posted 20/06/16 12:34 AM Has the car had a windscreen replaced at some stage? The weather strip that runs the lenght of the roof, is it intact? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92084-water-leaking-into-footwear-not-ac/#findComment-1596425 Share on other sites More sharing options...
Jamie_d Member 219 Member For: 10y 2m 11d Gender: Male Location: Wadalba 2259 NSW Posted 20/06/16 02:04 AM Share Posted 20/06/16 02:04 AM Had this exact problem in both fg I have at home. Turned out to be where cables run into the car inside the wheel well. Pulled plastic off and put silicone around all cables going into the car. I had to look into it because everytime I washed the car there was water at the drivers feet. Link to comment https://www.fordxr6turbo.com/forum/topic/92084-water-leaking-into-footwear-not-ac/#findComment-1596450 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,040 Member For: 10y 1m 29d Gender: Male Location: Canberra ACT Posted 20/06/16 02:48 AM Author Share Posted 20/06/16 02:48 AM Thanks everyone. This is a metric sh!t ton of water, so I'm guessing something topside rather than wheel well, as the car has been stationery but in heavy rain. Good call I think Ralph - while the weather strip looks good, the windscreen seal is very wet underneath about half way down on drivers side. Not sure on windscreen history, but screen isn't branded like the rest of the glass so I'm guessing it has been replaced. Next step will be to swing past a windscreen place for a look. Link to comment https://www.fordxr6turbo.com/forum/topic/92084-water-leaking-into-footwear-not-ac/#findComment-1596464 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 28d Gender: Male Location: Perth Posted 20/06/16 02:52 AM Share Posted 20/06/16 02:52 AM If it's the screen get it sorted ASAP mate. Rust time bomb otherwise. Is the black sealant use to bond the sceen consistent all the way around? If/when the screen is replaced if you can have a sticky beak around the window recess and make sure the paint is intact. Quite often it gets damaged when the installer scrape the sealant and then if you wind up with a leak it's rust city. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/92084-water-leaking-into-footwear-not-ac/#findComment-1596466 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,040 Member For: 10y 1m 29d Gender: Male Location: Canberra ACT Posted 20/06/16 09:09 AM Author Share Posted 20/06/16 09:09 AM Thanks for that - will do! Booked in tomorrow. Link to comment https://www.fordxr6turbo.com/forum/topic/92084-water-leaking-into-footwear-not-ac/#findComment-1596534 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,040 Member For: 10y 1m 29d Gender: Male Location: Canberra ACT Posted 21/06/16 11:50 AM Author Share Posted 21/06/16 11:50 AM Back to the drawing board - windscreen place said the screen is definitely fine and is the factory screen. Good news then for any rust issues there. Guy reckoned he often sees them get blocked up in front of the screen, and to remove the plastic panel around the wipers and have a good look clean out. I'll try that of the weekend. He thought all the door seals and stuff were fine too so if the above doesn't work, might be time to get the hose out. Link to comment https://www.fordxr6turbo.com/forum/topic/92084-water-leaking-into-footwear-not-ac/#findComment-1596865 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,040 Member For: 10y 1m 29d Gender: Male Location: Canberra ACT Posted 25/06/16 03:36 AM Author Share Posted 25/06/16 03:36 AM Yeah I pulled all that back. Unfortunately the carpet is dry, but the lining underneath (separated from carpet by a waterproof layer) is saturated. I'm leaning towards getting someone to dry it with some big heaters and peeling back the carpet. Anyone know of if this is a problem? Took out plastic trim behind wipers and everything was very clear and clean. This seal could be the cause? Link to comment https://www.fordxr6turbo.com/forum/topic/92084-water-leaking-into-footwear-not-ac/#findComment-1597603 Share on other sites More sharing options...
