Price check on GTX35* supercores.
Fireside
  • Member For: 15y 2m 30d
1 hour ago, MattyP said:
Yup
And so is the one I would buy
Would your's include the flapper mod too?
"highly recommended wastegate flapper modification has already been carried out with the housing itself professionally CNC ported and the OEM-spec 32mm port and flap upgraded to a higher-flowing 37mm setup"
16 minutes ago, mightbuyaford said:
Im personally not a fan of oversized flaps...
I'm too much of a turbo noob to understand if that's a legitimate comment or a lady bits joke.
Edited by Ezy2Confuze
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 9m 5d
It's a lady bits joke.
On a serious note -
An oversized flapper on a wastegate port is ideal as it seals completely.
A perfect sized flapper may wear even slightly on the edges and will only seal when it's perfect... hence nope.
An undersized flapper of course will not seal at all.
  • XR50T
  • Member For: 11y 8m 14d
I'd say more than 550rwkw is where an external gate should be looked at. As long as it's setup properly an internal gate will work correctly up to 550 maybe 600rwkw.
Mind you the 6466 is comes with an internal gate 1.07 Ford style rear housing and is rated to 900hp, yet to see one hit that figure yet though.
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 7m 15d
Anything T3 flange is fine to internal gate it's the bigger frame T4 options that don't even have an internal housing options is obviously suited to External
precision 6466 ..... Not a fan at all
precision in general can suck balls in regards to warranty, not dealing with their sh*t again
  • Site Developer
such a shame... they were promising so much when they pushed onto the xr6t market a while back with the past reputation of being horrible for warranty and/or failures...
