Boost Gauge T Piece
Six6
  • skids
  • Member For: 12y 4d
  • Gender: Not Telling
Here's how mine is setup, hope it helps. circled the sender and where the vac line runs to.
the primer really stands out in the engine bay on the lightning strike fords ;) see in the little bit of sun shining on it haha!
I'll have to t piece into this line when I install my blow off valve, as you can see it currently runs to sender that someone mounted to ecu bracket.
hopefully I labelled everything correctly ;)
  • Member For: 9y 8m 10d
The one connecting the BOV's vacuum source. Chuck in a t-piece there.
I did this too. And nice and easy to run signal wire across the firewall and into the cabin from there.
