k31th less WHY; more WOT Site Developer 29,542 Member For: 17y 2m 2d Gender: Male Location: Melbourne Posted 15/06/16 02:18 AM Share Posted 15/06/16 02:18 AM I think you'll find this thread comprehensive on the width or rubber/wheels on FG sedans http://www.fordxr6turbo.com/forum/topic/76399-fg-offsets-and-tyre-questions/ Link to comment https://www.fordxr6turbo.com/forum/topic/92013-fg-f6-sedan-build-to-600rwhp/page/6/#findComment-1595624 Share on other sites More sharing options...
BigMoscow Member 45 Member For: 9y 13d Posted 17/06/16 01:43 AM Author Share Posted 17/06/16 01:43 AM Just had all the quotes come back modifying the original turbo cam shafts valve springs cold air intake intercooler kit oil pump gears injectors twin fuel pump system battery relocation gear box mods (input shaft and clutches) 4inch mild steel exhaust hand controller freight,labour,tuning $18k the he whole system will be E85 compliant and everything will have room to spare should I go the E85 rout later on. Link to comment https://www.fordxr6turbo.com/forum/topic/92013-fg-f6-sedan-build-to-600rwhp/page/6/#findComment-1595927 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 1m 8d Gender: Male Location: Central Coast Posted 17/06/16 01:49 AM Share Posted 17/06/16 01:49 AM What was the spec of the cam? I really think it's unnecessary with the stock turbo Link to comment https://www.fordxr6turbo.com/forum/topic/92013-fg-f6-sedan-build-to-600rwhp/page/6/#findComment-1595928 Share on other sites More sharing options...
BigMoscow Member 45 Member For: 9y 13d Posted 17/06/16 02:07 AM Author Share Posted 17/06/16 02:07 AM It will be the atomic stage 4 cam. You are right, it is not. But they are not expensive to buy or to install. Plus it will help response, lag and help me reach my goals easier. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92013-fg-f6-sedan-build-to-600rwhp/page/6/#findComment-1595933 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 1m 8d Gender: Male Location: Central Coast Posted 17/06/16 02:12 AM Share Posted 17/06/16 02:12 AM I don't think that's how cams work There is always going to be a trade off Link to comment https://www.fordxr6turbo.com/forum/topic/92013-fg-f6-sedan-build-to-600rwhp/page/6/#findComment-1595936 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 20d Gender: Male Location: Perth Posted 17/06/16 02:19 AM Share Posted 17/06/16 02:19 AM higher lift and duration = more air in the motor. That's going to help response and consequencly power. Maxing duration/lift with out exceeding overlap the PCM can control is going to provide benefit over stock cams. Link to comment https://www.fordxr6turbo.com/forum/topic/92013-fg-f6-sedan-build-to-600rwhp/page/6/#findComment-1595938 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,542 Member For: 17y 2m 2d Gender: Male Location: Melbourne Posted 17/06/16 02:46 AM Share Posted 17/06/16 02:46 AM On 17/06/2016 at 2:19 AM, Ralph Wiggum said: Maxing duration/lift with out exceeding overlap the PCM can control Expand Correct me if I'm wrong, but isn't this difficult to achieve with hardware and/or tune? Link to comment https://www.fordxr6turbo.com/forum/topic/92013-fg-f6-sedan-build-to-600rwhp/page/6/#findComment-1595940 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 20d Gender: Male Location: Perth Posted 17/06/16 02:54 AM Share Posted 17/06/16 02:54 AM More difficult than a stock standard run of the mill tune, but highly doable. We'll soon find since Turboknapp has a set of bumpity bump sticks ready to go into the blue meanie. BA Non FPV have a set offset between the intake and exhaust cam. BF and FG have dual VCT so cam position relative to each other can be changed in relations to each out (ie overlap) Technically it's Exhaust Cam position relative to Intake. Link to comment https://www.fordxr6turbo.com/forum/topic/92013-fg-f6-sedan-build-to-600rwhp/page/6/#findComment-1595943 Share on other sites More sharing options...
BigMoscow Member 45 Member For: 9y 13d Posted 17/06/16 03:15 AM Author Share Posted 17/06/16 03:15 AM (edited) I like you Mightbuyaford. You are an enabler. It it was my thought exactly. Stage 4 Cams #306551 Duo Phased Advertised Inlet duration 262° Advertised Exhaust duration 257° Inlet duration at .050” lift 203° Exhaust duration at .050” lift 196° Lobe lift - inlet and exhaust .223” Valve lift - inlet and exhaust .455” Lobe centres Lobe centres 112degrees computer controlled Edited 17/06/16 03:20 AM by k31th posts merged. Try hitting "edit" if you're still within 10 minutes of posting your last post 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92013-fg-f6-sedan-build-to-600rwhp/page/6/#findComment-1595954 Share on other sites More sharing options...
BigMoscow Member 45 Member For: 9y 13d Posted 17/06/16 04:03 AM Author Share Posted 17/06/16 04:03 AM This will be more the fast enough for everything I want to do. There red will be suspension upgrades needed but I should be able to get into the 10s and be pretty competitive on the track. Plus it will still look stock enough to make an occasional rice burner/hsv owner and maybe even bike owners saying WTF later on I might invest in a bottom end see what numbers I can hit. Link to comment https://www.fordxr6turbo.com/forum/topic/92013-fg-f6-sedan-build-to-600rwhp/page/6/#findComment-1595960 Share on other sites More sharing options...
