  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 23d
57 minutes ago, k31th said:
(unless some tricky welding is done to an internal wastegate housing and then it's technically an external anyway :P ).
I said this ^^
If you weld the internally gated exhaust housing in any way to bypass the internal flapper, it's then no longer an internally gated housing.
If you just weld a pipe around the internal wastegate port and flapper section, then your internal gate can vent to wherever you want, but it's almost entirely pointless :)
If you buy a specific housing that has separate outlets for both the dump and wastegate, then this is almost as pointless as the previous method.
It's entirely possible that the ebay jobby is the part that is leaking.
  • Member For: 10y 6m 10d
Ill probably just put the old 4" dump back on for good measure but it wasn't that bad of a leak I believe..
This is on it atm
I'm dyslexic and cannot turn off simple functions in tapatalk
  • Site Developer
Yeah, that doesn't look like it seals around the dump/gate sections in the standard exhaust too well...
  • Site Developer
Of course it would sound good :P haha
if some of that "wastegate" noise you're getting is actually airflow that's meant to be pushing more air into your intake, it's a detriment :)
you can get the sound from an external wastegate relatively cheaply... obviously not as cheap as an eBay dump, though.
The dump pipe just got dumped then ? and hello sweet sweet boost, precious boost. Ill go external in a few weeks when I have some pocket money there are some legit nice ones a place in melbourne do.
  • Site Developer
It's just one of the possible problems, though... It's just an easy one to eliminate, especially if you have the correct size dump already.
Cut a hole in the exhaust housing MCM style :P Then you can mount and run an external gate with screamer, all while holding boost better than ever before haha
  • Site Developer
It's your tapatalk signature... turn your tapatalk signature off and that text won't show up
