  • Member For: 10y 4m 4d
Hey guys time to move up in the world and aim for 400rwkw on my BA with a BF 2007 turbo engine. Im about to purchase a set of 1000cc bosch E85/unleaded injectors and a Walbro 255LPH E85/unleaded fuel pump.
I am currently running 80lb / 800cc seimens bosch injectors and a Walbro 265LPH fuel pump woth a custom tune etc.
Now my question is do I need to get the shop to put them in for me (and charge me an arm and a leg or can I install them myself and drive I to the shop without any issues.
Also a side question, at what point do I need to change the fuel filter and fuel hoses if at all?
Edited by Hussydabomb
Spelling errors
https://www.fordxr6turbo.com/forum/topic/91991-e85-pump-and-injectors-retune/
  • Bronze Donating Members
  • Member For: 13y 9m 6d
1) Need bigger fuel pump. 460 or 044.
2) will need a reg to control the 460 if staying intank. 044 should be okay.
3) Fuel pump will be okay to change without needing a tune.
4) injectors I really don't know. You may be close enough that it runs. Mine started and ran with 1000cc injectors after having 42Lb injectors in it. Never drove it though other then onto the dyno.
5) ask if u can fit the injectors at the workshop if your that tight.
Fuel hoses will be okay.
You will need to change your fuel filter every 500 kays for 2000 kays as it will loosen all the crap in the tank.
  • RNS10S
  • Member For: 18y 8m 10d
Expand
No need to change injectors.
Leave the 255 and get a surge tank and you should be sweet.
Hoses will be fine but if you decide to change them Gates make a decent e85 rubber hose that's ethanol compliant.
Below graph shows mine with 80lb dekkas, 255 intank, plaz surge with Aeromotive A1000 pump.
422 is with United E85 / 414 is Caltex e-flex (E70)
Missed your question, if you change the injectors you wont be able to drive the car unless your tuner can load up a base file suited to the injectors you will be installing.
Ok ill probably just get the tuner to install the injectors for the sake of things and that off chance something goes wrong..
With the surge tank, is it going to smell like a space ship leaking fuel all the time?
I haven't purchased them yet so probably better to just go with an in tank pump that will be sufficient?
A well setup surge with quality lines won't smell at all.
Sufficient and good are 2 different things. If you aren't worried about running low on fuel upgrade the intank.
I'm personally a surge believer, other than super heating fuel
  • Moar Powar Babeh
  • Member For: 19y 7m 3d
I've had my car on e85 for close to three years now. No smell at all except what comes out of the pipes when its running.
I've got a process west surge and fuel lab main pump.
I return my fuel directly to the tank not the surge to avoid excess pressure in the return and unnecessary fuel heating.
My my options are basically run a 460 in tank with a fuel regulator or the 255 in tank with dual 044's into a surge tank.
Is one better than the other? And cost difference?
I'm dyslexic and cannot turn off simple functions in tapatalk
  • MattyP
  • Cruise Control
  • Member For: 12y 11m 22d
044s aren't ethanol rates full time
It's up to you. I say intank because simple and will.do the job. Others say surge
It's up to you
