  • MattyP
  • Cruise Control
  • Member For: 13y 29d
It's pretty restrictive at that power level
Lu82 had standard cat back with his 6235 and changed over to a bigger one and picked up a whole bunch of power
It's good but not that good
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 23d
The cat is by far the most restrictive part of the stock exhaust.
Most people change anything more than the cat for the sound/looks(tip/dump), with regard to FG's
  • Member For: 12y 3m 7d
Fg have a 3 inch exhaust? Will do 400kw easy why does it need an exhaust?
Same thing as my mate said. But the tuners swear you need a bigger one over 330.
  • Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds
  • Cruise Control
  • Member For: 14y 7m 12d
got stock exhaust with venom 5" cat at the moment. Spoke to the Venom rep and he said " Highest we have had one up to is 370rwkw with bigger injectors and a turbo side intake (as well as an intercooler kit) still with the stock catback. "
if I go to racewars im going to acquire a 4" system.... but will go back to the stock rear section after. I like the quiet sound.
Go all out dude, f*ck the 4" go a short exhaust straight out the side or something with no mufflers.
or at least straight through.
The guy I went with got there, decided his exhaust wasn't loud enough so cut it off with an angle grinder while there was still e85 dripping down it. That's called being a madcunt.
  • Like 4
  • Member For: 17y 6m 9d
This is sage advice!  Vote #1 madcunt
  • Cruise Control
funny thing is, you could go down with a stock system, then have a short/modded system and tune it at the event.... hmmmz. giving me bad ideas. good thing I wont be able to go anyways
  • Sandtrap Motorsport
  • Member For: 16y 6m 8d
IF you aren't bashing 2 step (etc), what gains would removing the mufflers make?
minimal or quite a difference?
I couldn't be bothered removing mufflers (etc) IF you aren't bouncing that 2-step, BUT would you want to do that anyways if you dont have oil pump gears?
