Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 10d Gender: Male Location: Perth Posted 06/09/16 03:38 AM Share Posted 06/09/16 03:38 AM I could tow the daily with the F6 to get into that category if you allow combined totals? Are you going Eff? Link to comment https://www.fordxr6turbo.com/forum/topic/91990-racewars-2017/page/21/#findComment-1610506 Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 8m 3d Posted 06/09/16 03:50 AM Share Posted 06/09/16 03:50 AM Yep I am entered so should be there. A couple of mates have entered aswell with 450+kW e series Falcons so we're planning to make a week of it down there. Another mate just missed out on his entry with his 600+kW el so hopefully some people drop out and he can get down there aswell. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91990-racewars-2017/page/21/#findComment-1610507 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 10d Gender: Male Location: Perth Posted 06/09/16 03:53 AM Share Posted 06/09/16 03:53 AM Sweet Eseries car at those power levels should do pretty well! Link to comment https://www.fordxr6turbo.com/forum/topic/91990-racewars-2017/page/21/#findComment-1610508 Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 8m 3d Posted 06/09/16 04:13 AM Share Posted 06/09/16 04:13 AM Yeh should go pretty well hopefully. Bit worried about the motor as I would like to turn it up to 500kw for the weekend but it's untested territory for stock el rods. I'm on the lookout for a set of second hand xr6 turbo Pistons so I can put a half built motor together with some spool rods then I can lift the limiter to 7500 and not worry about making a conrod shower. Link to comment https://www.fordxr6turbo.com/forum/topic/91990-racewars-2017/page/21/#findComment-1610509 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 10m 25d Gender: Male Location: OZ Posted 06/09/16 04:22 AM Share Posted 06/09/16 04:22 AM (edited) Atomic have a set of used stock size CP Pistons for $600. Give brad a call. 7500rpm is a big call for the I6 isn't it!? Edited 06/09/16 04:23 AM by IH8TOADS Link to comment https://www.fordxr6turbo.com/forum/topic/91990-racewars-2017/page/21/#findComment-1610511 Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 8m 3d Posted 06/09/16 04:36 AM Share Posted 06/09/16 04:36 AM Hmm might give him a ring and ask him cheers. 7500 is about as far as I would like to take it with standard rocker gear. I set the limiter at 6800 on my mates car with a standard motor for the last 3 years but am worried with more rpm that the stock rod bolts will stretch. Another mate has had his set at 7500 for 6 years now with a built motor and turns it up the 8000rpm for powerskids at powercruise. It's big rpm but as long as it has good lubrication and a good set of valve springs it's not really much diferent to the guys with SBC revving to 9000-10000rpm. Link to comment https://www.fordxr6turbo.com/forum/topic/91990-racewars-2017/page/21/#findComment-1610513 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 10d Gender: Male Location: Perth Posted 06/09/16 04:39 AM Share Posted 06/09/16 04:39 AM Check the skirt length on those CP's. Mine rattled like a mofo even with tight bore clearance.I wouldn't be comfortable running them up as high as your suggesting unless they have improved the skirts The set I had looked like they should have been in a CRF450 Link to comment https://www.fordxr6turbo.com/forum/topic/91990-racewars-2017/page/21/#findComment-1610514 Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 8m 3d Posted 06/09/16 04:51 AM Share Posted 06/09/16 04:51 AM Interesting wonder if they have made them in diferent skirt lengths. My mates has a set of CP's and has been in his for years but he also had them custom made as no one did a piston to suit the au SOHC chamber when he built it years ago. Do you have the thicker wrist pins in yours Ralph? The set I pulled out of my mates rb30 that was making around 450kw had a noticeable bend to them when rolling across the engineer bench couldn't believe it. Link to comment https://www.fordxr6turbo.com/forum/topic/91990-racewars-2017/page/21/#findComment-1610515 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 9d Gender: Male Location: Probably above atmospheric pressure Posted 06/09/16 05:31 AM Share Posted 06/09/16 05:31 AM (edited) On 06/09/2016 at 1:37 AM, turboknapp said: Stainless Cooler pipes??? Looks like a Motocross bike exhaust pipe Expand Correct, I cropped it a bit but it's from a bike Edit holy fck - looking forward to the E series smack down! Such RPMs, much boost, many wow. Edited 06/09/16 05:38 AM by -Stever- 5 Link to comment https://www.fordxr6turbo.com/forum/topic/91990-racewars-2017/page/21/#findComment-1610524 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 6d Gender: Male Location: Perth Posted 06/09/16 07:37 AM Share Posted 06/09/16 07:37 AM Does anyone know if they will have E85 tanked down to Albany. Link to comment https://www.fordxr6turbo.com/forum/topic/91990-racewars-2017/page/21/#findComment-1610541 Share on other sites More sharing options...
