  • 6 years later...
  • Member For: 9y 3m 15d
On 20/05/2016 at 2:00 PM, Ralph Wiggum said:
how far out is a few mm out? Are the teeth on the cam sprokets worn?
I got a similar issue I have popped the rocker cover open and found everything lined up but the 2 yellow pieces of chain to the notch 1 was on there perfect but the other was about 1/10 th of a tooth out if that literally 2mm
would this cause a rough idle at times intermittent I seem to get the over retard code at times
