  • Member For: 10y 10d
For those of you who have added oil temp or pressure gauges, where have you installed the senders?
I've added an oil temp gauge with a Specco sandwich plate that has 1/8 npt ports. Trouble is the thing won't stop leaking. I (and the mechanic) have tried tape, thread sealant and stag paste. Best result to date has been the stag paste I used, letting it cure off the car for a couple of days. I know have one spare plug leaking a little, but is still enough to put a drop of oil on the ground each night and gradually make a mess underneath.
Welding a bung into the sump doesn't seem to be the go as I would like to add an oil pressure at some stage.
At this point I'm thinking maybe a better quality (hopefully) non-thermostatic sandwich plate like this Earl's one:
http://www.ebay.com.au/itm/170636507085
Would obviously need some adaptors for 1/4.
The piece off the oil switch is another option, but again if I'm eventually adding two senders and there's already the turbo oil feed branching off there it is getting a bit messy.
What have the rest of you used in the past?
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 22d
T-piece off the turbo oil sender line with thread tape sealed perfectly for me.
Thanks for that.
Has anyone else tried a sandwich plate and had luck with a particular brand? I'm thinking it will be a bit neater especial I'll eventually want two senders and would rather not have a Christmas tree of t-pieces.
I'm thinking the quality of the sandwich plate I used was junk.
  • Member For: 12y 4m 9d
Man you can get a 1/8 npt T piece from most repco stores for around $12/$15, bit of thread tape and screw T piece into where you oil pressure switch taps into the block on the left side, just above the engine mount, then screw oil gauge sender into T piece and connect the wires the correct way around and happy days ??
  • Moar Powar Babeh
  • Member For: 19y 7m 9d
Npt male into bspp female yeah. Bspp male into npt female not so great.
  On 20/05/2016 at 12:41 AM, Ralph Wiggum said:
Are the sensors your using npt or bspp?
Sensors are NPT
  • Member For: 17y 5m 8d
Weld in sensors to sandwich plate? hahaha
I use a plate and it's fine but no idea on brand sorry.  Cheap sensors from "RaceTech" gauge kits as well.
Edited by -Stever-
  • 2 weeks later...
I think in the end I'm going to go for the t-piece. Not super keen on the Christmas tree effect if I add an oil pressure sender later but can't find anything particularly decent for a sandwich plate, despite liking the idea of them.
Am I correct in thinking the factory oil pressure switch is 1/4 npt? If so, I'll get an 1/4 npt male to female, with a 1/8 npt female half way along for the temp sender.
