discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 7m 5d Gender: Male Location: Probably above atmospheric pressure Posted 17/06/16 12:23 PM Share Posted 17/06/16 12:23 PM (edited) What a mysterious little plug into the side of the car. Can't just be a chassis ground wire can it? What's on the other end? Maybe it's a plug they use to connect other things to when you can afford to buy an entire car. Maybe an unused sunroof plug? Edited 17/06/16 12:27 PM by -Stever- Link to comment https://www.fordxr6turbo.com/forum/topic/91923-the-stockist-300rwkw-member/page/6/#findComment-1596077 Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 4m 3d Gender: Male Location: Perth Posted 17/06/16 01:00 PM Share Posted 17/06/16 01:00 PM Who did the stereo install? Did they chew out the holes for the speakers with their teeth or what? Could have filed it down or something. Jeez 2 Link to comment https://www.fordxr6turbo.com/forum/topic/91923-the-stockist-300rwkw-member/page/6/#findComment-1596082 Share on other sites More sharing options...
Krazy Kyle Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds Cruise Control 2,697 Member For: 14y 8m 9d Gender: Male Location: Work Posted 18/06/16 02:34 AM Author Share Posted 18/06/16 02:34 AM yeah, wasnt super excited by the work, will have to spend some time on it one day. was a place NOR, as much as ill say. On 17/06/2016 at 12:23 PM, -Stever- said: Maybe it's a plug they use to connect other things to when you can afford to buy an entire car. Expand ha..... that's hill-arious because its a ute :P. There is one on both sites. little unit with one screw and 2 wires. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91923-the-stockist-300rwkw-member/page/6/#findComment-1596124 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 7m 5d Gender: Male Location: Probably above atmospheric pressure Posted 18/06/16 05:31 AM Share Posted 18/06/16 05:31 AM Dual sunroofs, that'd be MAD! Link to comment https://www.fordxr6turbo.com/forum/topic/91923-the-stockist-300rwkw-member/page/6/#findComment-1596138 Share on other sites More sharing options...
Krazy Kyle Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds Cruise Control 2,697 Member For: 14y 8m 9d Gender: Male Location: Work Posted 05/07/16 11:05 AM Author Share Posted 05/07/16 11:05 AM Had a suspension check done last week... Didnt really find anything wrong. part of me was hoping they would, as id like to improve the front end and would have given me something to blame about why its not better.... Link to comment https://www.fordxr6turbo.com/forum/topic/91923-the-stockist-300rwkw-member/page/6/#findComment-1599363 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,579 Member For: 17y 2m 20d Gender: Male Location: Melbourne Posted 05/07/16 11:06 AM Share Posted 05/07/16 11:06 AM I think that's the first ever pedders suspension check sheet without 10 things needing to be fixed 2 Link to comment https://www.fordxr6turbo.com/forum/topic/91923-the-stockist-300rwkw-member/page/6/#findComment-1599364 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m 28d Gender: Male Location: Western Sydney Posted 05/07/16 11:12 AM Share Posted 05/07/16 11:12 AM Dude just get rid of the saddle bush completely along with the plates that sit around the leaf pack. It doesn't increase harshness at all imho and doesn't need any other parts to get it done. If not at least get some metal plates made up to replace them, they only last a few thousand kms if you give it a bit. 1-2hr job in your driveway and your done. Link to comment https://www.fordxr6turbo.com/forum/topic/91923-the-stockist-300rwkw-member/page/6/#findComment-1599366 Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 4m 3d Gender: Male Location: Perth Posted 05/07/16 11:37 AM Share Posted 05/07/16 11:37 AM (edited) On 05/07/2016 at 11:06 AM, k31th said: I think that's the first ever pedders suspension check sheet without 10 things needing to be fixed Expand I go to the same Pedders, they seem very honest and never seem to overcharge for anything. They've even not charged me for a 28 point check one time cos they didn't find anything. Also did the best price I could find for fitting of diff bushes. Not what you usually hear about Pedders eh Edited 05/07/16 11:38 AM by Lennox Link to comment https://www.fordxr6turbo.com/forum/topic/91923-the-stockist-300rwkw-member/page/6/#findComment-1599371 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,579 Member For: 17y 2m 20d Gender: Male Location: Melbourne Posted 05/07/16 11:39 AM Share Posted 05/07/16 11:39 AM I was only stirring I know that some pedders are OK and some are not. Same with any chain/franchise style business. Link to comment https://www.fordxr6turbo.com/forum/topic/91923-the-stockist-300rwkw-member/page/6/#findComment-1599372 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 7d Gender: Male Location: Perth Posted 05/07/16 12:43 PM Share Posted 05/07/16 12:43 PM I used to use the same pedders. I stopped after the car arrived home from a wheel alignment with a crooked steering wheel and a "click" in steering just past centre. Turns out the guy that did the alignment had loosened the wheel in an effort to straighten it after the alignment, then realised the wheel to column is a tapered square so it only fits in 90deg increments. He forgot to re tension the bolt securing the wheel. I could live with that as it took less than a turn to be tight back up to spec. What pissed me off was a a flat out denial that they where involved in the wheel being loose. I rang them and gave them the heads up as it wasn't the usual guy that did my alignments but they where not interested. I wasn't expecting anything from them either. Pretty sad as id been going there for a long time and had spent a decent amount of coin there and recommended others go there as well. Kyle, if you need an alignment go see Dean at tyre power tell him I sent you. Also change to a 19 or 18 wheel and the front will improve. Link to comment https://www.fordxr6turbo.com/forum/topic/91923-the-stockist-300rwkw-member/page/6/#findComment-1599390 Share on other sites More sharing options...
