Turbo replaced but not related to problem
GKGSJQKS
  • Member For: 11y 28d
its load related then and probably not engine itself. check the things keify mentioned.
Does it happen at a particular speed or more noticible at a given speed. I say speed and not rpm coz im thinking tailshaft centre bearing but it's just another guess really mate without a great deal to go on
my exhaust would rattle when idling in gear. moved the rubbers around a bit and did the hose clamp trick on the rear one to lift the tip up a bit when I was doing some other stuff to the car on the weekend. been quiet since lol, didnt even set out to fix it..
  • Member For: 10y 1m 27d
Sorry I have no useful input except to say that I bet Fluff is proud that kokenose is a thing now. Good luck bud.
  • Banned
  • Member For: 9y 6m 1d
  • Gender: Not Telling
Got the car diagnosed and the report was "3 diff bushes + bladearm bushes". So in the diagrams below that would be "blade control arm front kit" and would the 3 diff bushes consist of "differential pinion, bracket mount kit" (two that I can see) and "differential rear centre support kit"?
Rear suspension diagram for FORD AUSTRALIA FALCON FG Sedan - 2008-onRear suspension diagram for FORD AUSTRALIA FALCON FG Sedan - 2008-on
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 8m 8d
Yep, those 5 bushes are the ones the report is referring to...
Will replacing those 5 bushes solve your original problem? I'm doubtful...
  • skids
  • Member For: 11y 11m 20d
maybe tailshaft related then? unless im blind and hes had that checked
  • Site Developer
Essentially it's because if you had all of those bushes shagged there would be a bunch of other noticeable issues...
Main rear diff bush and side diff bushes being buggered would mean a very noticeable "clunk" in the rear end on almost all "load changes" e.g. taking off from a standstill, changing gears roughly, coasting downhill.
Trailing arm bushes if they're stuffed can cause weird rear end wobbles, especially when turning, but are definitely not as noticeable as diff bush problems.
