barnz Member 3,047 Member For: 11y 3m 15d Gender: Male Location: Brisbane Posted 28/04/16 02:22 AM Share Posted 28/04/16 02:22 AM its load related then and probably not engine itself. check the things keify mentioned. Does it happen at a particular speed or more noticible at a given speed. I say speed and not rpm coz im thinking tailshaft centre bearing but it's just another guess really mate without a great deal to go on my exhaust would rattle when idling in gear. moved the rubbers around a bit and did the hose clamp trick on the rear one to lift the tip up a bit when I was doing some other stuff to the car on the weekend. been quiet since lol, didnt even set out to fix it.. Link to comment Share on other sites More sharing options...
GKGSJQKS Banned 259 Member For: 9y 8m 18d Gender: Not Telling Posted 28/04/16 10:13 AM Author Share Posted 28/04/16 10:13 AM I would say it's more noticeable at lower speeds, just cruising around because it's easier to hear, but there has to be light throttle input involved. Link to comment Share on other sites More sharing options...
Franga Donating Members 256 Member For: 10y 4m 14d Gender: Male Location: Melbourne, VIC Posted 28/04/16 10:44 AM Share Posted 28/04/16 10:44 AM Sorry I have no useful input except to say that I bet Fluff is proud that kokenose is a thing now. Good luck bud. Link to comment Share on other sites More sharing options...
GKGSJQKS Banned 259 Member For: 9y 8m 18d Gender: Not Telling Posted 05/05/16 05:30 AM Author Share Posted 05/05/16 05:30 AM Got the car diagnosed and the report was "3 diff bushes + bladearm bushes". So in the diagrams below that would be "blade control arm front kit" and would the 3 diff bushes consist of "differential pinion, bracket mount kit" (two that I can see) and "differential rear centre support kit"? Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 23d Gender: Male Location: SW Sydney Posted 05/05/16 05:41 AM Share Posted 05/05/16 05:41 AM Correct If you pay for his flights and provide beer, apparently Ralph wiggum provides a fifo diff bush fitting service....? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,292 Member For: 16y 10m 25d Gender: Male Location: Melbourne Posted 05/05/16 05:45 AM Share Posted 05/05/16 05:45 AM Yep, those 5 bushes are the ones the report is referring to... Will replacing those 5 bushes solve your original problem? I'm doubtful... Link to comment Share on other sites More sharing options...
GKGSJQKS Banned 259 Member For: 9y 8m 18d Gender: Not Telling Posted 05/05/16 05:53 AM Author Share Posted 05/05/16 05:53 AM 8 minutes ago, k31th said: Will replacing those 5 bushes solve your original problem? I'm doubtful... Why is that? Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 2m 7d Gender: Not Telling Posted 05/05/16 05:54 AM Share Posted 05/05/16 05:54 AM 8 minutes ago, k31th said: Yep, those 5 bushes are the ones the report is referring to... Will replacing those 5 bushes solve your original problem? I'm doubtful... maybe tailshaft related then? unless im blind and hes had that checked Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,292 Member For: 16y 10m 25d Gender: Male Location: Melbourne Posted 05/05/16 05:57 AM Share Posted 05/05/16 05:57 AM Essentially it's because if you had all of those bushes shagged there would be a bunch of other noticeable issues... Main rear diff bush and side diff bushes being buggered would mean a very noticeable "clunk" in the rear end on almost all "load changes" e.g. taking off from a standstill, changing gears roughly, coasting downhill. Trailing arm bushes if they're stuffed can cause weird rear end wobbles, especially when turning, but are definitely not as noticeable as diff bush problems. Link to comment Share on other sites More sharing options...
GKGSJQKS Banned 259 Member For: 9y 8m 18d Gender: Not Telling Posted 05/05/16 06:04 AM Author Share Posted 05/05/16 06:04 AM Ah I see. Is there a degree to the level of wear with these bushes and the symptoms exhibited or is it the case that they have to be either fine or totally stuffed? Link to comment Share on other sites More sharing options...
