  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 11d
He said he had oil pump gears, and it'd be a miracle to make the power he does without valve springs haha.
  • Member For: 14y 2m 17d
Lol @ k31th.. very true
Atomik Valve Springs and billet oil pump gears are currently in it.
Thanks sixman its not all about the power its more so how its delivered. Currently on track days it takes to long to spool and get power on rolling starts. Need nearly 60kms in second gear to get spool happening fast.
The precision seems to be the win, how much boost can the f6 bottom end hold on stock pistons and rods with 98?
  • Member For: 20y 9m 29d
I had 450rwkw with stock fg valve springs and no float, was that way for about 12 monthd. Did upgrade them for peace of mind.
I know what you mean about delivery. In second gear the precision is spooling hard by 45km/hr. In comparison the gtx3576 comes on hard just under 40km/hr.
If your tracking it definitely think about a surge tank and also driveshaft upgrade.
Not sure how much a stock bf bottom can take.
For track work in a manual, nelsonian is the man to chat to about turbo choice
That's impressive on stock valve springs.
I currently have a 600hp built tailshaft. The gtx3576 just lacks that mid to top that I want for the straights.
I am pretty set on the precision I think, what front and rear housing should be used any idea?
Its my daily but I go to the track once a month or so. Mainly track for racing on the straight with rolling start around 40km
I had the 4inch front housing rotormaster sell it with. Used my stock rear housing.
The other option is to look at some of the bigger bolt on low mount turbos with a smaller rear housing for quick spool. Lots of talk around about the precision 6466 with 0.82 rear and the borg warner efr range.
Yeah, the little gtx lacks mid to top even on the street.
Edit: play with the diff ratio?
Edited by sixman
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 20d
I can help you out with Genuine Precision turbo's also bud ;)
  • MattyP
  • Cruise Control
  • Member For: 13y 17d
In b4 matt says his fondness of modifying standard turbos.
*Cough* make your own t04z coldsided billet wheeled 35r *cough*
Cheers sixman, some thinking to look into and think about.
I don't want to change diff gears as I dont want them shorter and if they are taller I will lose some of that pull
that's great Jet I'll be hitting you up for goodies :)
MattyP that's all I was originally going to do. The precision seems to meet all my needs where as the garrett gets close but cant meet at all areas
  • 1 month later...
  • 4 weeks later...
  • Member For: 11y 5m 15d
Why not a 6466? Great thread over on ford forums where they back to backed it to the 3576 baby turbo on 300rwkw vs the 6466 with 420 AND outspooling the stock fg turbo. Even at 450rwkw you'd still have room to move in the future if you want more power
Heres a cached link if you dont have a login for there
http://webcache.googleusercontent.com/search?q=cache:zhtv2NREqrAJ:fordforums.com.au/showthread.php%3Ft%3D11436193+&cd=4&hl=en&ct=clnk&gl=au
