  • XR50T
  • Member For: 12y 24d
3 & 4 are the worst on the FG manifold, it's the most turbulent area.
  • New Member
  • Member For: 11y 11m 24d
Every time I have done a bigger plenum swap on spring pressure I have found the boost has changed with a drop as rpm increase. Only a pound or two but I feel you would be better off using some form of boost control to be able to level boost out again if required. I have a spoolinboost plenum you can add to the comparisons if your interested.
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 24d
I with other knowledgeable individuals have concerns that when it comes to plenums and AFT that outright CFM or total HP does NOT paint a fair picture of what is the "best"
some very big consideration to all of these style tests is something that can be overlooked and that's "off boost" performance
yup funny but we spend more time in this area than on boost
this is where the N/A path comes into the mix and can be a very big difference in best case product
it could be seen as silly but I believe if these plenums were tested on a Barra 4.0 NA the results may very well be different
but who cares about drivability xD
  • Like 2
  • Member For: 19y
Unfortunately,  I can only speak of my own personal  experience. My Plazzy race series is absolutely  fantastic with normal everyday driving. As we  only have  a base map in it ( more road  tuning on Sat),  I expect that it will only get better.   Have you tuned many Jet?
The majority that I  know with Hypertune's ect. All have big cams and vernier gears. I'm  guessing  that drivability isn't a concern for those guys. ..
Expand
I agree and we will now be doing 20 psi and and one much higher.  I think that  the test mule will be running  a gtx55 turbo,  so we might stretch its legs a little....
  • New Member
Gaz097 unfortunately for us some utter scum has just started copying our plenums and turbo manifolds. We have never sold on gumtree. If anyone has further info please pm me. Cheers Will from spoolinboost
  • Bronze Donating Members
  • Member For: 13y 10m 4d
