Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 7d Gender: Male Location: Perth Posted 23/04/16 08:21 AM Share Posted 23/04/16 08:21 AM Csc should be 14 to 17 mm taller that the distance from the gearbox mounting face on the bellhousing to the clutch spring fingers Fact! 1 Link to comment Share on other sites More sharing options...
T-Rex Donating Members 98 Member For: 13y 6d Gender: Male Posted 23/04/16 03:15 PM Author Share Posted 23/04/16 03:15 PM Okay so I forgot to check here before I did it, had a great time changing my slave back over. I sat there with my mate going look at this there's like 1mm difference between them that must be it! So put it all back in and it's still not going into gear while running.... As far as I knew all that had to happen is the clutch bolted together and was straight down the center.... What have I missed? I put it back together how it came off the first motor but I must have done something wrong Link to comment Share on other sites More sharing options...
T-Rex Donating Members 98 Member For: 13y 6d Gender: Male Posted 24/04/16 04:44 AM Author Share Posted 24/04/16 04:44 AM In summary, everything should be as it was originally but won't disengage. The car lurches forward if started in gear with the clutch in. The CSC is the original again and the clutch went back together how it came apart, the only think I can think of is that maybe the pressure plate got damaged when I put my motor back in however I didn't check last night. I'm waiting on a snake camera so I can stick it in and watch while the pedal gets pushed but other wise I have no idea Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 7d Gender: Male Location: Perth Posted 24/04/16 04:46 AM Share Posted 24/04/16 04:46 AM Did you have the clutch apart? Link to comment Share on other sites More sharing options...
T-Rex Donating Members 98 Member For: 13y 6d Gender: Male Posted 24/04/16 10:50 AM Author Share Posted 24/04/16 10:50 AM You better believe I did! It's a twin plate as well, and now I think of it the centre plate may have been swapped around when I cleaned it but the clutch disks themselves are definitely right because I made sure of the stamping (flywheel side-transmission side) Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 7d Gender: Male Location: Perth Posted 24/04/16 11:31 AM Share Posted 24/04/16 11:31 AM Did you mark the flywheel/intermediate/pressure plate so it all went back together the same? Link to comment Share on other sites More sharing options...
T-Rex Donating Members 98 Member For: 13y 6d Gender: Male Posted 24/04/16 02:25 PM Author Share Posted 24/04/16 02:25 PM Witness marks in the interest of keeping balance or just for reassembly? I forgot because I didn't think that would apply hence not having much experience with clutches.... I'm going to have to pull it apart at a minimum I'm guessing? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 7d Gender: Male Location: Perth Posted 24/04/16 11:41 PM Share Posted 24/04/16 11:41 PM Keeping the flywheel/in plate/pressure plate and both frictions relationship the same prevents any issue with run out in the clutch or the possibility of alinging two high posts with each other and causing drag. Link to comment Share on other sites More sharing options...
T-Rex Donating Members 98 Member For: 13y 6d Gender: Male Posted 25/04/16 02:47 AM Author Share Posted 25/04/16 02:47 AM Ahh gotcha, but surely it wouldn't cause the clutch to stop disengaging? Aren't the pressure plates 'supposed' to be self adjusting? Or is that just generic crap I read in my googling? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 7d Gender: Male Location: Perth Posted 25/04/16 04:25 AM Share Posted 25/04/16 04:25 AM What clutch are you using? Link to comment Share on other sites More sharing options...
