  • Too heavy needs boost
  • Member For: 11y 8m 18d
Ok so youtube is being a *beep* and will not load my video. So I have a pic. Is this excessive oil that could have caused it to rub. A fanny hair of play up and down and back and forth.8c36884c09fc8563d23ab64e43a7ee3c.jpgc746cdc0cf2d0925ce3f48a0e9104dee.jpgtime for catch can maybe?
Watch "Gtx3576r rubbing on front cover" on YouTube
f*cked.
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 14d
I doubt it would be the oil that you can see as that looks like a "normal" amount...
My theory is that sometimes the piping connection to the turbo doesn't have enough flex and it can eventually put enough sideways pressure on the compressor housing causing it to hit the edge of the compressor wheel blades... but that's only a guess.
Bendoco is running the same turbo same time purchase and his did the same with factory crossover
  • Member For: 14y 10m 3d
Love your vids bizkets.
I remember seeing about the same amount of oil around the front of my turbo when I hadn't checked it in a long time.me turbo still going strong.
Very strange considering you say there is not much shaft play
Im not david attincunt but if I wanted to I would be the sh*t. Sick as bro.
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 24d
Brad your turbo sounds exactly like Don's and the fact it's probably well within spec for shaft play and the fact it's just "rumbling"
I had a feel of Don's and it was definitely something suss in the shaft/bearing set but not out of spec
what it is I can't say unless it's stripped but you have to try pretty hard to kill a new specc BB turbo .... It's either
noisy , run dry on oil, excessive heat
that's about it ....
Lots of oil. Heat wise ask simon at morpowa. Just f*cking pissed off. Seriously check out my new whipf3dccc41e3774f320abf134ed56f29df.jpg
  • 3 weeks later...
Turbo is off. Oil line seemed slow even with the filter off. Did find a rear housing bolt 90% out2e8058259e59aad89edc29845b94c3c1.jpg
Other then that it seemed fine. More shaft play back and forth. So hopefully I can get it to mtq to have a look at it. My brother was saying whats the point of having a inline oil filter for the turbo when I service it every 5k.
