Checking out 2nd hand turbo
kb351
  • Member For: 17y 3m 9d
I had a bit of a a search on the forum but couldn't find this sort of info...
I'm looking at getting a 2nd hand gt3582 from a BA that still has the rear housing attached.
Apart from obvious damage to fins is there anything I can do to check that the turbo is Ok to use?
I'm guessing a small amount of side to side shaft play is ok, is any back and forward play acceptable?
Should they spin freely for long when turned by hand or can they get sticky if left sitting?
  • Trust me bro...
  • Member For: 9y 11m 12d
Why are you getting a second hand turbo?
Imo unless you are paying next to nothing for it it may not be your best option. On that note if you are paying next to nothing then it is probably stuffed.
I had a gt35r sit in my kitchen cupboard for 2 years and it got a little sticky. As soon as it got an oil supply again it freed up.
Only asking $250 for it with rear housing so not a big expense - point taken pretty cheap so probably stuffed but I figure that if it does spin its worth a look but the only thing I know to look for apart from obvious damage is housing cracks and scoring on the front from the blades but any help would be appreciated.
I figure $250 plus repairs would still keep me well within new pricing...
  • skids
  • Member For: 12y 13d
  • Gender: Not Telling
My cars got a second hand turbo on it and only thing wrong is the idiot who installed it (didn't notice the turbo he pulled off was flapper modded...lucky I have it to swap exhaust housing).
I'd check the play in the shaft and the other things you mentioned.
Edited by johnxr6t
Cheers guys,
Thanks for the help.
I might send the whole thing off to get the flapper mod done and get it professionally checked out for piece of mind.
This is for my FG, so to keep my gt3576 and go gt3582 no matter what I would need another turbo.
Going back to my original query, I was trying to see if anyone could help with advice for me to to check it out, the economics of the whole exercise is another story.
To recap - I'll check for excess play in shaft, scoring on body by blades, cracking in rear housing.
Anything else I need to look out for?
  • Moar Powar Babeh
  • Member For: 19y 3m 18d
As long as the bearings arent rough/notchy when you spin it and the wheels don't touch the housings when you apply axial or radial force by hand to the shaft, go for it.
Don't expect the bearings to be silent just not notchy or rough.
  • Like 2
