discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 22d Gender: Male Location: Probably above atmospheric pressure Posted 13/04/16 06:42 AM Share Posted 13/04/16 06:42 AM If you drive a performance car like a grandma then you'll get what you deserve 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91869-engine-oil-for-running-in/page/2/#findComment-1586004 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 17d Gender: Not Telling Posted 13/04/16 06:56 AM Share Posted 13/04/16 06:56 AM On 13/04/2016 at 6:42 AM, -Stever- said: If you drive a performance car like a grandma then you'll get what you deserve Expand Lol. Not everyone is mechanically savvy. I remember signs on cars growing up that would say "running in, 80kph max, overtake". Some folks think that a car has to be babied to be run in and some say thrash from the get go. There is a proper way to run in an engine depending on its application and output but it should not be done gently or excessively. Link to comment https://www.fordxr6turbo.com/forum/topic/91869-engine-oil-for-running-in/page/2/#findComment-1586010 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 23d Gender: Male Location: Perth Posted 13/04/16 07:03 AM Share Posted 13/04/16 07:03 AM Opinions on engine run in proceses are like r-soles. Too many variables to say do xyz and you'll be fine. Unless the engine builder gave you specific instructions use the engine in all the rpm/load points you'll expect it to perform at and don't spend too much time on any individual point. Link to comment https://www.fordxr6turbo.com/forum/topic/91869-engine-oil-for-running-in/page/2/#findComment-1586011 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 17d Gender: Not Telling Posted 13/04/16 07:26 AM Share Posted 13/04/16 07:26 AM True that Ralph. That is the beauty of the internet. More bullsh*t than the local rodeo. I learnt how to run in an engine, in various states of rebuild, from one of South Australia's leading engine dyno operators back in 2001. The procedure I gave was the road equivalent. I personally wouldn't deviate from that too much but hey, each to his own. Link to comment https://www.fordxr6turbo.com/forum/topic/91869-engine-oil-for-running-in/page/2/#findComment-1586012 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 23d Gender: Male Location: Perth Posted 13/04/16 08:25 AM Share Posted 13/04/16 08:25 AM Did every engine you ran in have the same piston to bore clearance? Same piston type? Same ring type/gap/bore finish? Same interned application/power level? Like I said too many variables for a one size fits all Link to comment https://www.fordxr6turbo.com/forum/topic/91869-engine-oil-for-running-in/page/2/#findComment-1586020 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 25d Posted 13/04/16 08:46 AM Share Posted 13/04/16 08:46 AM Make sure u strip the engine afterward to check the burn pattern across the piston to check your head porting is correct and maximized. Link to comment https://www.fordxr6turbo.com/forum/topic/91869-engine-oil-for-running-in/page/2/#findComment-1586023 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 17d Gender: Not Telling Posted 13/04/16 09:06 AM Share Posted 13/04/16 09:06 AM Silly questions Ralph. I never said one size fits all. Lol what answer/s do you expect? I tell you what, you run your car in how you want and I'm do mine the way I described. Brb checking my blinker fluid. Link to comment https://www.fordxr6turbo.com/forum/topic/91869-engine-oil-for-running-in/page/2/#findComment-1586026 Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 5m 22d Gender: Male Location: Perth Posted 13/04/16 01:25 PM Share Posted 13/04/16 01:25 PM I ran in my engine this way: - drain water from sump - remove rust internals - add diesel oil - make limiter go bang bang bang - check compression half a year later - bask in glory of pristine engine that's quiet as 3 Link to comment https://www.fordxr6turbo.com/forum/topic/91869-engine-oil-for-running-in/page/2/#findComment-1586060 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 10m 15d Gender: Male Posted 13/04/16 01:38 PM Share Posted 13/04/16 01:38 PM Ask a silly question; how do the manufacturers run in engines? Or do they at all? Pretty sure most people just pick up the keys & drive it Link to comment https://www.fordxr6turbo.com/forum/topic/91869-engine-oil-for-running-in/page/2/#findComment-1586062 Share on other sites More sharing options...
