Engine oil for running in
daveyboii
  • Member For: 17y 3m 15d
If you drive a performance car like a grandma then you'll get what you deserve :P
  • Puff
  • Member For: 10y 1m 10d
Lol. Not everyone is mechanically savvy.
I remember signs on cars growing up that would say "running in, 80kph max, overtake".
Some folks think that a car has to be babied to be run in and some say thrash from the get go.
There is a proper way to run in an engine depending on its application and output but it should not be done gently or excessively.
  • Moar Powar Babeh
  • Member For: 19y 5m 16d
Opinions on engine run in proceses are like r-soles.
Too many variables to say  do xyz and you'll be fine.
Unless the engine builder gave you specific instructions use the engine in all the rpm/load points you'll expect it to perform at and don't spend too much time on any individual point.
  • Puff
True that Ralph. That is the beauty of the internet. More bullsh*t than the local rodeo.
I learnt how to run in an engine, in various states of rebuild, from one of South Australia's leading engine dyno operators back in 2001.
The procedure I gave was the road equivalent.
I personally wouldn't deviate from that too much but hey, each to his own.
  • Moar Powar Babeh
Did every engine you ran in have the same piston to bore clearance? Same piston type? Same ring type/gap/bore finish? Same interned application/power level?
Like I said too many variables for a one size fits all
  • Puff
Silly questions Ralph. I never said one size fits all.
Lol what answer/s do you expect?
I tell you what, you run your car in how you want and I'm do mine the way I described.
Brb checking my blinker fluid. :P
  • Sandtrap Motorsport
  • Member For: 16y 3m 14d
I ran in my engine this way:
- drain water from sump
- remove rust internals
- add diesel oil
- make limiter go bang bang bang
- check compression half a year later
- bask in glory of pristine engine that's quiet as
  • Like 3
