***VX*R8*** Member 202 Member For: 11y 2m 5d Gender: Male Posted 09/04/16 09:43 AM Share Posted 09/04/16 09:43 AM I have a used GT3582R with .7 front cover to go on my G6ET but am thinking about getting a GTX3582R instead. Is there much difference between the two turbos as far as real world performance and is the cost difference worthwhile? Will be running kpm1500 injectors, PW stg2 intercooler, 4" intake, 4" dump & 100cell cat, 400lph fuel pump, Crow valve springs and billet oil pump gears. Also have a manual conversion to go in at some stage and E85 is a possibility... Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 4m 29d Posted 09/04/16 09:46 AM Share Posted 09/04/16 09:46 AM Gtx is 10X better. 1 Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 7m 16d Gender: Male Location: Central Coast Posted 09/04/16 10:05 AM Share Posted 09/04/16 10:05 AM If you already have gt3582r just put an 11 blade billet wheel on it Then you get gtx3582r 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,972 Member For: 9y 10m 21d Gender: Male Location: South Australia Posted 09/04/16 10:15 AM Share Posted 09/04/16 10:15 AM That is what I'm currently doing. My stock turbo has just shown signs of being worn. I had a spare external gate gt35r so I used the core from that, added a gtx wheel and machined the 0.7 comp cover to fit the larger wheel. With a flapper job and other small mods for the larger compressor it will come in at less than a grand. Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 7m 16d Gender: Male Location: Central Coast Posted 09/04/16 10:23 AM Share Posted 09/04/16 10:23 AM You shouldnt even need to machine the housing to suit Alternatively you could also buy a bigger comp wheel/cover/backplate and use any falcon turbo and upgrade it to a gtx3584r Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,972 Member For: 9y 10m 21d Gender: Male Location: South Australia Posted 09/04/16 10:43 AM Share Posted 09/04/16 10:43 AM Maybe I was getting confused with the previously decided 66 mm comp wheel? I decided against that, because, from my calculatoring the compressor would be too big for the combination of the stock turbine wheel as well as the internal wastegate. I almost went gtw3884r with adapter but at twice the cost of a stock upgrade as well as having a stock motor and driveline I chose the lesser path...for now. If I was to buy a gtx35r outright, I wouldn't. I'd go bigger but that is just me. Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 7m 16d Gender: Male Location: Central Coast Posted 09/04/16 10:46 AM Share Posted 09/04/16 10:46 AM 66mm comp wheel is gtx3584r which is also the t04z billet wheeled cold side It seems a little mismatched but I think that's the biggest comp you could go on that turbine. Its been done alot by jim gianna, race equipped and monsta torque. Alot of people dont realise that the gtw is a step down from the gtx If I had my time again id make a gtx3576r also because going to manual is better for spool Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,972 Member For: 9y 10m 21d Gender: Male Location: South Australia Posted 09/04/16 11:20 AM Share Posted 09/04/16 11:20 AM Good points there. The gtw should make more power according to numbers and figures but as mentioned the compressor wheel has the drawbacks of being old tech. There are other reasons not to use a gtw turbo but google can provide those reasons to interested people. It did for me. "Is the cost difference worthwhile?" Decide how much power you want, your dollar per kw and what will achieve those goals. Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 7m 16d Gender: Male Location: Central Coast Posted 09/04/16 01:58 PM Share Posted 09/04/16 01:58 PM It a bigger turbo Its very close to a t04z. I just love the sound of a t04z hence why I want the 66mm comp cover+wheel Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 7m 16d Gender: Male Location: Central Coast Posted 09/04/16 01:59 PM Share Posted 09/04/16 01:59 PM The horniest turbo ive heard 4 Link to comment Share on other sites More sharing options...
