Steve O Member 106 Member For: 13y 11m 28d Gender: Male Location: Sydneys Northern Beaches Posted 29/03/16 11:10 AM Share Posted 29/03/16 11:10 AM Hi everyone, Had a ba few years ago and just picked up a 07 bf mk 2 xr6t with the zf. Literally on the drive home from buying it the engine light came on and when it was given some boot for a second to merge the handbrake light and a few others flashed on and the Speedo stopped working. Turned the car off and on and the Speedo works but engine light remains. I had it looked at by a mechanic literally 8 hours before I bought it and he said it needs a new coil pack which is making it miss other than that is fine. Any help as I had a coil go on the ba and it wasn't this bad. Dead set shattered. Cheers Link to comment Share on other sites More sharing options...
bamk2f6tornado Bronze Donating Members 777 Member For: 11y 1m 22d Gender: Male Location: Rockhampton Qld Posted 29/03/16 11:51 AM Share Posted 29/03/16 11:51 AM Have you pulled the code for the engine light? Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 1d Gender: Male Location: Probably above atmospheric pressure Posted 29/03/16 11:52 AM Share Posted 29/03/16 11:52 AM (edited) Check battery terminals are clean. Mine did the flash everything and drop speedo trick twice right anfter a new battery was fitted and the terminals left unprotected. Leads had oxidised heaps. Scraped em off, clamped on and sprayed terminal protector gunk on it, all good. Probably won't stop engine light but it's cheap and easy to do. The cars act haywire if voltages fluctuate. Edited 29/03/16 11:53 AM by -Stever- Link to comment Share on other sites More sharing options...
Steve O Member 106 Member For: 13y 11m 28d Gender: Male Location: Sydneys Northern Beaches Posted 29/03/16 07:37 PM Author Share Posted 29/03/16 07:37 PM Going to get the code pulled today. Has a slight miss at idle and under load so I assumed coil packs. Disconnected the battery and cleared the engine light. Bastard I bought it off is claiming the old "I've never had a warning light".. Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 1m 26d Gender: Male Location: WA, Perth Posted 05/07/16 03:28 AM Share Posted 05/07/16 03:28 AM since I am on a role here and I am digging up old threads, I thought I may as well try this one. Did you get this resolved in the end? You last visited on the 22nd of June, so you might drop by soon @Steve O Hopes are high. Link to comment Share on other sites More sharing options...
