Graham420 New Member 12 Member For: 8y 11m 17d Posted 18/03/16 12:34 PM Share Posted 18/03/16 12:34 PM (edited) Hey all iv recently got my self a xr6t ba 03 manuel and im having problems with my boost? I think at first I thought it was bad fuel because i filed up twice at a shity servo but its still happening the problem is when i try give it some stick its bo 2003 xr6t BA Edited 28/03/16 07:27 PM by Dagabond 1 Link to comment Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 9y 11m Posted 18/03/16 12:49 PM Share Posted 18/03/16 12:49 PM Try cleaning if not replacing boost controller run off the wastegate actuator and sit next to ya battery if ya battery is in the standard postion and give ya throttle body a clean. Search on here to found out how to do both things. Good luck mate. 1 Link to comment Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 9y 11m Posted 18/03/16 01:00 PM Share Posted 18/03/16 01:00 PM Mine did the same thing. Cleaned the Boost controller put it back on and it never did it again. Might not be the problem but start with that easy little job and cleaning the throttle cleaned up a rough idle at the traffic lights. I ended replacing the controller if I remember right it was about $50-$60 buck for a genuine part. 1 Link to comment Share on other sites More sharing options...
Grass Donating Members 447 Member For: 21y 19d Gender: Male Location: Sydney Posted 18/03/16 01:27 PM Share Posted 18/03/16 01:27 PM The problem is ??? Your post doesn't look complete... Link to comment Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 9y 11m Posted 18/03/16 01:33 PM Share Posted 18/03/16 01:33 PM To translate "when I try to give it some stick it bo" bo meaning bogs there ya go the problem is solved. Invoice will be in the mail :-) Link to comment Share on other sites More sharing options...
stubbietubbie Filthy weeb Member 1,870 Member For: 12y 20d Gender: Male Posted 18/03/16 03:41 PM Share Posted 18/03/16 03:41 PM I'm only here to compliment the best thread title on this forum in ages. Carry on. 6 Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 11m 22d Gender: Male Location: Perth Posted 18/03/16 09:36 PM Share Posted 18/03/16 09:36 PM I'm with Stubster...solid thread title haha. 1 Link to comment Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 9y 11m Posted 18/03/16 11:41 PM Share Posted 18/03/16 11:41 PM It has to be the longest " Start new topic" heading I have seen before, and Ive done my fair share of reading on this forum as has alot of others. Also welcome Graham420 you'll will work it out mate. 1 Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 3m 15d Gender: Male Location: Brisbane Posted 19/03/16 01:27 AM Share Posted 19/03/16 01:27 AM In order, boost solenoid clean/bypass test sus it all out. Throttle body clean. any other symptoms like a rough idle or stalling? TPS could be sus. All ok do coils and plugs coz although your post is incomplete it sounds like its going to sh*t under load rather than boost cut or over boosting coz in that case you would probably report something like "goes hard then just dies at X rpm" Link to comment Share on other sites More sharing options...
Graham420 New Member 12 Member For: 8y 11m 17d Posted 19/03/16 08:32 AM Author Share Posted 19/03/16 08:32 AM Haha it only posted half my issue anything over 3000rpm now if I flatn it feels like its cutting in an out then its loosing all power after a noticeable klunk nois and kicks back in and its getting worse I pretty much cant wind my turbo up past half way I dont no to much pretty green in this area appreciate all the helpfull information the engine is all stock too Sent from my SM-G900I using Tapatalk Link to comment Share on other sites More sharing options...
