Boosturd Member 60 Member For: 9y 1m 21d Posted 17/03/16 11:09 PM Share Posted 17/03/16 11:09 PM Hi guys, First time poster but have been stalking the forums for a number of months now. Recently sold my Ba falcon and have upgraded to a 2013 manual FG MkII.. I noticed yesterday a new noise in my transmission, it sounds like a very slight grind, almost like something catching. This only happens when and results in: - Car is in gear with the clutch pushed in - Car is moving forward/back. Pushing it causes this intermittent noise to start periodically - Time between noises increases the higher gear it is in. For example twice per foot in 1st, once every 2 feet in 6th - I can feel a very slight vibration with this noise through my shifter if I hold it A guy I trust with mechanical issues has told me that it most likely isn't a pressure plate or driveline issue. Any help/past experience any of you have had with anything similar to this would be greatly appreciated. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/91807-help-please-fg-mkii-manual-transmission-issue/ Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 11y 10m 29d Gender: Male Location: NOR Perth Posted 18/03/16 11:12 AM Share Posted 18/03/16 11:12 AM Is this the typical rollover noise? I dont have a manual but think I read it before... Hopefully someone smart chims in soon Link to comment https://www.fordxr6turbo.com/forum/topic/91807-help-please-fg-mkii-manual-transmission-issue/#findComment-1582777 Share on other sites More sharing options...
sd1800 Member 51 Member For: 14y 3m 11d Posted 23/03/16 03:21 AM Share Posted 23/03/16 03:21 AM I can confirm it isn't rollover noise. Rollover noise is just a rattle at idle with the clutch OUT, or at <1000rpm rpm in gear. As per your second point and as you have already indicated, it seems to be gear related rather than RPM (pressure plate) or road speed(driveline). I would as a first port of call replace the gearbox oil with the Penrite stuff which is relatively inexpensive. I use mainlube, but it's expensive as sin and if it turns out it doesn't resolve the issue and you need to drop the brand new oil it will be a big $$$ waste. Good luck finding out what it is! Link to comment https://www.fordxr6turbo.com/forum/topic/91807-help-please-fg-mkii-manual-transmission-issue/#findComment-1583218 Share on other sites More sharing options...
Boosturd Member 60 Member For: 9y 1m 21d Posted 02/04/16 03:30 AM Author Share Posted 02/04/16 03:30 AM On 23/03/2016 at 3:21 AM, sd1800 said: I can confirm it isn't rollover noise. Rollover noise is just a rattle at idle with the clutch OUT, or at <1000rpm rpm in gear. As per your second point and as you have already indicated, it seems to be gear related rather than RPM (pressure plate) or road speed(driveline). I would as a first port of call replace the gearbox oil with the Penrite stuff which is relatively inexpensive. I use mainlube, but it's expensive as sin and if it turns out it doesn't resolve the issue and you need to drop the brand new oil it will be a big $$$ waste. Good luck finding out what it is! Expand Cheers for your replies PTR and sd I think putting some expensive oil is definitely a good idea and at the top of my priorities. I do get a small amount of rollover noise but nothing half as bad as I have heard on other cars so I'm hoping new oil will fix that right up. As for progress I will update anything that I find out but don't know how long that will take as its only noisy in confined spaces (like pulling into my garage) so I'm not overly concerned, it is just a bit annoying. Link to comment https://www.fordxr6turbo.com/forum/topic/91807-help-please-fg-mkii-manual-transmission-issue/#findComment-1584507 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 4m 24d Gender: Male Location: WA, Perth Posted 02/07/16 01:36 PM Share Posted 02/07/16 01:36 PM Where are you located? Link to comment https://www.fordxr6turbo.com/forum/topic/91807-help-please-fg-mkii-manual-transmission-issue/#findComment-1598886 Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 4m 30d Gender: Male Location: Perth Posted 03/07/16 02:55 AM Share Posted 03/07/16 02:55 AM Ok, there is rollover noise, but usually it's audible in neutral / clutch depressed. Stock clutch had this / aftermarket clutch with billet slave cylinder had this. So it was definitely the box. I used redline shockproof yellow and it quietened it down a touch. But my old tr6060 was a war veteran, haunted beat up on past with recurring issues in its later years lol Link to comment https://www.fordxr6turbo.com/forum/topic/91807-help-please-fg-mkii-manual-transmission-issue/#findComment-1598927 Share on other sites More sharing options...
